Create a mission
This workflow describes how to create a mission in ArcGIS Mission Manager.
Create a mission in ArcGIS Mission Manager
A new mission creates resources that are used for situational awareness and communication. These resources include teams who can communicate with each other during a mission, a mission map for coordination and visualization of mission members, submitted geospatial data, contextual layers, and much more. The following steps describe how to create a mission. For additional details, see Create New Mission tab.
  1. Click Create New Mission on the home screen.
    The Create a New Mission panel appears with a map view and mission configuration options.
  2. Provide the following mission information:
    • Mission name (required)
    • Map options:
      • Create a new map
      • Use an existing map that is accessible in your portal
    • Capabilities (Chats and Location Tracking by default)
    • Summary (optional)
    • Description (optional)—Additional information relevant to the mission, similar to the summary.
    • Tags (optional)—Tags allow quick retrieval for future searches. You can choose tags from the drop-down list or create custom tags. Click Enter after typing a tag to save it.
    • Terms of Use (optional)—Any special restrictions, disclaimers, limitations, or conditions for use can be included here.
    Anything included here can be edited on the Mission Details page.
  3. Choose a basemap basemap.
    A default basemap is provided.
    If using a basemap in an alternate projection, it is advised that these basemaps be stored in a group and configured for your portal to default to them.
  4. Select the desired map extent for your mission map. If using an existing web map the mission map extent will use the extent of the web map.
  5. Click Create Mission.
    A dialog box appears with a status bar, annotating layer creation status as the layers are being constructed on the portal. Upon completion, a message indicates that the mission creation is successful. If mission creation fails, the reason is displayed on the status dialog box.
  6. Click Done.
The Mission Details configuration page opens.
Create a New Mission from a Template
Additionally, a mission can be created from a template. When creating a mission from a template, all reports and materials associated with a Mission when it was created will be rebuilt in the new mission. However, Members and Teams will need to be recreated as these are variables that can change with personnel. Learn more about Creating a New Mission from a Template.
Add mission details
The Mission Details page allows you to define and modify certain aspects of the mission, such as members, teams, the mission map, tasks reports, and any materials you want to provide for mission participants.
Overview tab
On the Overview tab, you can view information about the mission, including the following:
  • Mission Thumbnail
  • Mission Owner
  • Mission Tags
  • Mission ID
  • Creation date
  • Date of last modification
You also have the following options:
  • Change the information entered during the mission creation in the About this Mission section.
  • Select or edit the mission thumbnail.
  • Change the mission's status between draft, active, and complete, as necessary.
  • Open your mission and participate.
  • Delete your mission.
  • Create a mission dashboard.
  • Create a mission template.
  • Create a mission flow
You can also use the other tabs on the Mission Details page to add information to your mission.
Members tab
The Members tab allows you to add members to the current mission. The list of portal members is determined by your organization's portal.
  1. Add mission members.
    Adding a portal user to the current mission creates a mission member. This allows the member to access details, content, and materials about the mission and to actively contribute to the mission.
Teams tab
The Teams tab allows the mission owner to create, edit, and delete teams in the current mission. These teams are composed of members added to the mission on the Members tab. Mission members can be part of more than one team, or none, as teams are not required for a mission.
  1. Create the teams for your mission.
    You can create any number of teams.
  2. Add members to those teams.
    Add members to the teams you created. Members can be part of multiple teams or none at all.
  3. Set members with a role (if desired).
  4. Set the team avatar with a graphic of your choice.
Mission members can be designated as a Mission Member or Mission Lead. By default all members are mission members except for the Mission Owner.
Map tab
Use the Map tab to create your mission map. The map tab includes a view-only mission map to gain an understanding about the layers within the mission. The mission owner can also enter the mission map editor. The map editor features tools for editing and styling mission maps, such as adding reference layers or graphics to provide additional context to the mission.
Tasks tab
The Tasks tab provides an overview of all tasks and task related activities associated with a mission. The task tab allows a mission owner to establish Task Types which tasks can be associated with and extend defining the types to Mission Leads in the mission. Additionally, tasks can be filtered and viewed based on their criteria and lists of tasks can be uploaded via csv.
The task tab also allows users to batch upload a csv of tasks, create a new task, or edit an existing task directly from this view.
Reports tab
The Reports tab displays mission reports and sensor reports, allowing mission analysts to preview existing reports or create new ones. Report details display the title, who created the report, and a preview of the report itself. Additionally, you can create a report or use a report template shared to your organization to use in your mission.
Materials tab
Mission members can provide supporting resources and information for mission members on the Materials tab. These can include, but are not limited to, pictures, PDF files, PowerPoint slides, and links to other web mapping applications such as ArcGIS Survey123 surveys and ArcGIS QuickCapture projects.
Change your mission status
The mission status can be changed on the Mission Details page. You have the options of Draft, Active, and Complete. You can change your mission status at any time. To change your mission status, see Mission status. You can also change a mission to active status only from within the Mission Analyst interface.
You are now ready to participate in a mission.
