Apply labels
A label must be created before it can be applied to components. Once a label exists, it appears on the Labels drop-down menu when registering components and can also be applied to registered components from the component's Overview page.
Once applied, labels appear on the component's Overview page and the component is included in any collections built with collection expressions that contain the label.
Apply labels to individual components
To apply labels to an individual component from the component's Overview page, complete the following steps:
  1. Access ArcGIS Monitor if necessary.
    The Home page appears.
  2. Click Monitoring.
    The Monitoring page appears. Registered components are listed alphabetically by component name.
  3. Optionally, do any or all of the following:
    • Click a category on the side of the page to filter the list by that category.
    • Click Sort and change the sorting method.
    • Click Filter and create a query to filter the list.
    • Click Columns and specify the columns to hide or show.
    • Position the pointer at the edge of a column's header and drag the column's edge to resize it.
    • Click Labels to filter the list by the labels that you choose.
    • Type a keyword in the Search by component name or address text box to search for specific components.
  4. Click Apply labels in the Labels column for the component to which you want to apply labels.
    The Apply labels pop-up appears.
  5. Click the name of each label that you want to apply to the component.
    You can type a keyword in the Enter label name text box to find specific labels.
    The label or labels appear next to the component's name in the Labels column on the Monitoring page.
    Tip:
    If the label that you want to add doesn't exist, click Create new label in the pop-up to create a label and apply it to the component.
Apply labels to multiple components
To apply labels to multiple components from the Monitoring page, complete the following steps:
  4. Check the check box next to the name of the components to which you want to apply labels.
  5. Click Apply labels.
  6. Click the name of each label that you want to apply to the component.
    The label or labels appear in the Labels column of each chosen component on the Monitoring page.
    Tip:
    If the label that you want to add doesn't exist, click Create new label in the pop-up to create a label and apply it to the chosen components.
