Add layers from a URL
You can add the following types of layers to Map Viewer using a URL:
Add a CSV layer from a URL
A comma-separated values file (CSV) is a web-based text file that typically includes location information.
When adding a .csv file to the map from a URL, the location information in the file must be latitude and longitude coordinates. To add a .csv file containing location information of a different type, such as addresses, add it as a hosted feature layer.
Complete the following steps to add a CSV layer:
  1. Do one of the following:
    • On the Contents (dark) toolbar, click Add , and choose Add layer from URL.
    • Open the Layers pane , and from the drop-down arrow, choose Add layer from URL.
  2. Provide the layer's URL in the URL text box.
  3. Choose the appropriate data type from the Type drop-down list if necessary.
  4. Click Next.
  5. Choose one of the following:
    • Create a hosted feature layer and add it to the map.
    • Reference the file from the URL and add it to the map.
  6. Click Next.
  7. Complete the steps in the following sections to reference a .csv file from a URL or create a hosted feature layer from the URL.
Reference a file from a URL
To reference the .csv file from its URL and add it directly to the map, complete the following steps:
  1. Follow the steps in the previous section to add a .csv file from a URL.
  2. Define the properties of the fields for the layer:
    1. Optionally, provide display names and field data types.
    2. Click Next.
    3. Optionally, specify which location fields to use.
      The location information must be latitude and longitude coordinates. If the location information is of a different type, such as addresses, add the .csv file as a hosted feature layer instead.
  3. Click Add to map.
    The data is added to the map and now appears in the Layers pane .
Create a hosted feature layer from a URL
If the .csv file you are referencing contains location information of a type other than latitude and longitude—for example, addresses or place names—create a hosted feature layer before adding it to the map. Create a hosted feature layer if you need full editing capability or if there is a large amount of data in the referenced file.
If the file is larger than 50 MB, creating a hosted feature layer from the file URL may not be supported.
To create a hosted feature layer with a large file, download the file and add the file to the map.
Complete the following steps to create a hosted feature layer from a URL:
  1. Follow the steps above to add a .csv file from a URL.
  2. Follow the steps to publish a .csv file beginning at step 7.
  3. Click Create and add to map.
Add a KML layer
KML is an XML-based file format used to represent geographic features.
Complete the following steps to add a KML layer:
  4. Click Add to map.
Add an ArcGIS Server web service
An ArcGIS Server web service is a map, image, or feature resource that is located on an ArcGIS Server site.
Complete the following steps to add an ArcGIS Server web service to a map:
  2. Provide the service or layer's URL in the URL text box.
    To find the REST URL of an ArcGIS Server service, open the Services Directory page, https://myserver.com/arcgis/rest/services, and browse to the service you want to share. You can then copy the URL from the browser's address bar. Do not append any parameters, such as a token, to the URL.
    For example, a map service URL is in the format https://myserver.com/arcgis/rest/services/folder/service/MapServer. To add a single layer from the service, append the number associated with the layer shown in the Layers list on the Services Directory page to the service URL. For example, https://myserver.com/arcgis/rest/services/folder/service/MapServer/0.
    For more information and examples of ArcGIS Server service URLs, see Components of ArcGIS URLs.
  3. Choose the appropriate service type from the Type drop-down menu if necessary.
  4. Optionally, do the following to append custom parameters to requests made to the service:
    1. Under Custom parameters, click Add custom parameter.
    2. Provide the name of the parameter you want to append in the Parameter text box.
    3. Provide the parameter value in the Value text box.
    4. Repeat these steps for each parameter you want to append.
    The specified custom parameters are automatically applied to all requests made to the service.
  5. Optionally, for secured services, turn on the Store credentials with the layer toggle button to automatically authenticate access to the service.
  6. Optionally, if the layer can be used as a basemap, turn on the Use as basemap toggle button to use the data as a basemap layer. If the toggle button is not turned on, the data is added to the map as an operational layer.
  7. Click Add to map or Use as basemap.
    The data is added to the map and now appears in the Layers pane or the Basemap pane .
Add a GeoRSS layer
GeoRSS is a live web feed that includes geographic features and locations.
Complete the following steps to add a GeoRSS layer to a map:
Add a GeoJSON layer
GeoJSON is an open standard geospatial data interchange format that represents simple geographic features and their attributes.
Complete the following steps to add a GeoJSON layer to a map:
  4. Click Next.
  6. If you are referencing the file from the URL, click Add to map.
  7. If you are creating a hosted feature layer, click Next and complete the following steps:
    1. Type a title.
    2. Choose a folder in My Content where you want to save the item.
    3. If your organization has set up content categories, click Assign categories and select up to 20 categories to help people find your item.
      You can also start typing a category name to narrow the list of categories.
    4. Optionally, type tags that describe the item.
      Separate the terms with commas (for example, Federal land is considered one tag; Federal, land is considered two tags).
      As you type, you can select any of the suggested tags that appear. Suggestions are generated from tags you have added previously.
    5. Optionally, provide a summary that describes the item.
    6. Click Create and add to map.
Add a tile layer
A tile layer is a set of web-accessible tiles that reside on a server. When you add a tile layer from the web, the tiles are accessed by a direct URL request from the web browser.
Access to the appropriate tiles in the tile layer depends on the URL you provide for the tile layer. The URL contains parameterized values that Map Viewer uses to request the tiles that correspond with the extent and scale of the map as you pan and zoom.
Complete the following steps to add a tile layer to a map:
    Provide a URL that contains the level, column, and row placeholders in the following format: https:// ... /{level}/{col}/{row}.png or https:// ... / {z}/{x}/{y}.png. The URL can also contain a placeholder for the subdomains where the map tiles are stored. You can get this URL from the data provider.
    For example, the URL for the OpenCycleMap tile layer contains parameterized values in braces {}: https://www.opencyclemap.org/:https://{subdomain}.tile.opencyclemap.org/cycle/{level}/{col}/{row}.png.
    Tile layers added from the web must use the Web Mercator (Auxiliary Sphere) coordinate system to ensure proper display in Map Viewer.
  4. Optionally, if the layer can be used as a basemap, turn on the Use as basemap toggle button to use the data as a basemap layer. If the toggle button is not turned on, the data is added to the map as an operational layer.
  5. Click Next.
  6. In the Title text box, type a title for the layer.
    The specified title will be displayed in the Layers pane (or the Basemap pane if you add it as a basemap).
  7. In the Attribution text box, type any copyright information or required attribution information for the tile layer provider.
    The attribution information will be displayed at the bottom of the map.
  8. If the tile layer contains one or more subdomains, use a comma-separated list to specify the tile layer's subdomain labels in the Subdomains text box.
    Subdomains are used by the tile layer provider to distribute tile requests across multiple servers. Not all tile layers have subdomains. If the tile layer does not have subdomains, the Add tile layer window does not display the subdomain field. If you are unsure of the subdomain labels, contact the tile layer provider.
    If the tiles are distributed across multiple servers, you must provide subdomain information.
  9. Optionally, turn on the Set tile extent to the current extent of the map toggle button.
    When you turn on this option, Map Viewer sets the tile extent to include only those tiles visible in the map at the time that you enable the option. Map Viewer will only display tiles in that extent. However, because the tiles are not clipped to fit the extent, tiles may extend beyond the extent.
  10. Click Add to map or Use as basemap.
Add a knowledge graph layer
A knowledge graph layer is a group layer with collections of feature layers and tables representing geospatial and nonspatial entities and relationship types. A knowledge graph layer can be created by referencing a knowledge graph service. To learn more about how to create and manage knowledge graph layers, see Get started with ArcGIS Knowledge in the ArcGIS Pro help.
Complete the following steps to add a knowledge graph layer to a map:
  2. Provide the knowledge graph service URL in the URL text box.
    To find the REST URL of an ArcGIS Server service, open the Services Directory page, https://myserver.com/server/rest/services, and browse to the service you want to share. Copy the URL from the browser's address bar. Do not append any parameters, such as a token, to the URL. You can also copy the URL from the knowledge graph service item page in the portal.
    For example, a knowledge graph service URL is in the format https://myserver.com/server/rest/services/Hosted/myKnowledgeGraph/KnowledgeGraphServer.
  5. Click Add to map.
Add an OGC API - Features layer
When you add an OGC API - Features layer to Map Viewer, you must choose one sublayer at a time. To add more layers from the same OGC API - Features layer, repeat the steps to add a layer and choose a different sublayer each time.
Complete the following steps to add an OGC API - Features layer to a map:
    The layer must contain a spatial field.
  5. Click Next.
  6. Choose a layer to add.
    You can only add one layer.
  7. Click Add to map.
Add an OGC WCS web service layer
When you add an OGC Web Coverage Service layer to Map Viewer, you must choose one sublayer at a time. To add more layers from the same OGC WCS layer, repeat the steps to add a layer and choose a different sublayer each time.
When you add an OGC WCS layer to a map, you can specify custom parameters to append to requests made to the service.
Complete the following steps to add an OGC WCS layer to a map:
    You can set a custom parameter to define which OGC WCS specification version should be used by client apps to query the WCS layer item.
  5. Optionally, add a custom parameter to define the OGC WCS specification version to be stored with the WCS layer item.
    1. Type the word version in the Parameter field.
    2. Provide the OGC WCS version number in the Value field.
    If you do not define a version, clients use the default OGC WCS specification version defined in the service.
  6. Click Next.
  7. Choose a layer to add.
  8. Click Add to map.
Add an OGC WFS web service layer
When you add an OGC Web Feature Service (WFS) layer to a map, you must choose one sublayer at a time. To add more layers from the same WFS layer, repeat the steps to add the layer and choose a different sublayer each time.
When you add an OGC WFS layer to a map, you can specify custom parameters to append to requests made to the WFS. For example, if the service requires an access key, the key can be included as a custom parameter for requests made to the WFS. When custom parameters are specified, they are automatically applied to all requests made to the WFS. Layer-specific custom parameters such as spatial operators are not supported.
The coordinate system of the WFS layer and the basemap used in the map must be compatible.
Complete the following steps to add an OGC WFS web service layer:
You can only add WFS 2.0 layers that support GeoJSON output.
  5. Click Next.
  7. Type a value for Max feature limit in the text box or use the arrow buttons to set the limit.
    When the layer is loaded in the map, each request to the WFS service will return a maximum number of features, as defined by the max feature limit.
Add an OGC WMS web service layer
OGC WMS is a map that follows the OGC Web Map Service specification.
When you add an OGC Web Map Service (WMS) layer to a map in Map Viewer, you can add all the layers in the service or select the layers to add. If you add all the layers in the service, all the layers are added to the map, but only the first layer is displayed. To display the other layers, click the Contents button, click the OGC WMS layer name, and check the boxes next to the layers you want to appear in the map.
When you add an OGC WMS layer to a map, you can specify custom parameters to append to requests made to the WMS. For example, if your WMS layer supports styles, styles can be used as a custom parameter for layer requests. If an access key is required, the key can be configured as a custom parameter for all requests made to the WMS. Custom parameters are applied to all layers that you specify to be added to the map. To append different custom parameters to specific layers only, you must add those layers separately.
By default, when you add an OGC WMS layer to the map as a basemap, the first 10 layers in the service are added and all 10 layers are visible. You can select different layers in the WMS service to add to the basemap when you add the WMS to the map or if you add the WMS as an operational layer and move it to the basemap.
Complete the following steps to add an OGC WMS web service layer:
  5. Optionally, if the layer can be used as a basemap, turn on the Use as basemap toggle button to use the data as a basemap layer. If the toggle button is not turned on, the data is added to the map as an operational layer.
  6. Click Next.
  7. Choose specific layers in the OGC WMS service to add to the map, or click Select all to add the entire service.
    If you specified custom parameters, they are applied to all the layers you choose. To append different custom parameters to specific layers only, you must add those layers separately.
  8. Click Add to map or Use as basemap.
Add an OGC WMTS web service layer
Each layer in an OGC Web Map Tile Service (WMTS) contains a set of cached images and can have a different tiling scheme than the other available layers in the WMTS service.
Only add the layer or layers that your map audience needs to access, because a large number of cache image tiles can clutter the map and it may take a long time to draw, especially in web browsers.
You must go back through the process of adding the WMTS to your map.
When adding an OGC WMTS layer to your map, you can specify custom parameters to append to requests made to the WMTS. For example, if the service requires an access key, the key can be included as a custom parameter for all requests made to the WMTS.
Complete the following steps to add an OGC WMTS web service layer:
    4. Optionally, check the Append only to requests that draw or query layers check box.
      If you leave the check box unchecked, the parameter is appended to all requests made to the service.
    5. Repeat these steps for each parameter you want to append.
  6. Click Next.
  7. Choose a layer to add and select a Matrix tile option from the drop-down menu.
