Get help with error and warning messages from the ArcGIS Pro assistant (beta)
Use the Error Assistant mode of the ArcGIS Pro assistant (beta) to get explanations for error and warning messages encountered during processing and suggestions for resolving them. Error Assistant mode is available only from an error or warning message raised during processing.
The assistant in Error Assistant mode uses information submitted in an error log and a template prompt to generate specific guidance about the error or warning message. The error log contains messages, tool parameter values, and tool environment values captured during the process when an error or warning message occurred. You can edit the details in the attached error log to modify the information submitted to the assistant.
The assistant uses a variety of Esri data sources to analyze the error or warning message and suggest approaches to resolve a problem. It cannot access your datasets, run processes, or make direct changes to your project.
Access Error Assistant mode
Click Ask Assistant in one of the following locations to access Error Assistant mode from an error or warning message:
The Assistant (Beta) pane appears in Error Assistant mode with a default prompt, Explain the error and suggest steps to resolve it, and an error log attached.
Error Assistant mode supports errors and warnings generated by geoprocessing tools and models only. It is not available for other ArcGIS Pro messages.
Review and submit an error message help request
To review and submit your request for error message help, complete the following steps:
  1. Optionally, modify the default prompt.
  2. Optionally, click Edit details on the Error Log to review the information included in the request.
  3. Optionally, uncheck any messages or parameters you do not want to include in the error log, or modify the values as needed.
  4. Press Enter or click Ask the question to submit the prompt.
    The prompt and the response provided by the assistant are recorded in the Assistant (Beta) pane. The response may include troubleshooting steps, information about the error or warning, and links to related resources. The assistant can suggest solutions but cannot make changes to your project.
    After a request is submitted, the error log can no longer be edited.
