Get started with the ArcGIS Pro assistant (beta)
The ArcGIS Pro assistant (beta) is embedded in ArcGIS Pro and uses artificial intelligence (AI) to answer your questions, perform actions, generate queries, and generate Python code for ArcPy.
The ArcGIS Pro assistant (beta) includes the following modes:
  • ArcGIS Pro Help—The assistant answers ArcGIS Pro help documentation questions in a conversational manner.
  • ArcGIS Pro Actions—If corresponding AI-assisted actions are available, the assistant performs the actions upon request.
  • ArcPy Code—The assistant generates Python code snippets that use the ArcPy Python site package.
  • Graph Query—The assistant generates openCypher queries for a given knowledge graph schema. These queries can then be used in knowledge graph workflows.
  • Query Layer—The assistant creates query layers by generating SQL queries for a specified database connection and table schemas.
The assistant also has an Error Assistant mode that you can access only by clicking Ask Assistant on certain error and warning messages.
Install and use the assistant
To get started with the ArcGIS Pro assistant (beta), complete the following steps:
  1. Ensure that ArcGIS Pro 3.8 with Semantic Search is installed.
  2. Install the ArcGIS Pro assistant 3.8 (beta).
  3. Sign in to an eligible ArcGIS organization.
  4. Open the Assistant (Beta) pane.
  5. Choose a mode, and submit a prompt.
See Set up and use the ArcGIS Pro assistant (beta) for detailed instructions.
Before you can access the ArcGIS Pro assistant (beta), your organization administrator must configure your ArcGIS Online organization or ArcGIS Enterprise organization to allow the use of AI assistants. ArcGIS Online organizations must also turn off the Block Esri apps and capabilities while they are in beta setting. Your role must include privileges to use AI assistants in ArcGIS Online or ArcGIS Enterprise, as applicable.
Credits
Using the ArcGIS Pro assistant (beta) does not consume credits. However, the results displayed may recommend a workflow that requires credits.
Security and privacy
The ArcGIS Pro assistant (beta) automatically collects your submitted prompts, enabled functions, and the final response to help improve product performance and reliability. Do not enter production or sensitive data. By using the assistant, you acknowledge and consent to this data being collected and used for product improvement purposes.
Prompts are not used to train Esri or third-party AI models.
AI transparency cards are available with more security and privacy details.
Learn more about privacy at Esri
Limitations and bias
The following limitations apply:
  • An ArcGIS Online or ArcGIS Enterprise organizational account is required to access the ArcGIS Pro assistant (beta). Other account types, such as public accounts, are not currently supported.
  • Suggestions generated using artificial intelligence can be misleading or inaccurate. Apply human judgment when interpreting and acting on the assistant's outputs to avoid potentially reinforcing any unintentional biases in the AI models used by the ArcGIS Pro assistant (beta).
  • At its discretion, Esri may implement a rate limit on AI assistants to maintain performance.
Resources
Use the following resources to learn more:
