ArcGIS.Core.Data Namespace / Table Class
    Table Class Methods
    For a list of all members of this type, see Table members.
    Public Methods
     NameDescription
    Public Method Performs common statistics functions on one or more fields in this table or feature class. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodCreates an InsertCursor instance in memory. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Creates a new row in the table with a system assigned object ID. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverloaded.
    Public MethodCreates an UpdateCursor instance in memory. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Deletes the rows in the database selected by the specified query. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets the archive table associated with this table or feature class if it is archived-enabled. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the possible contingent values for the given field name based on the values of the row buffer.
    Public MethodGets a IReadOnlyList of controller datasets of a specific Dataset type that this table or feature class participates in. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the data store of this dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Dataset)
    Public MethodGets the TableDefinition of this dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the ID associated with this table. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets the Join object from which this joined table was created. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the name of the dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Dataset)
    Public Method Gets the URI path to the dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Dataset)
    Public MethodGets the RegistrationType of a dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Dataset)
    Public Method Gets a value indicating whether this table is archive-enabled. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a value indicating whether this table supports attachments. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets a value indicating whether this Table supports the concept of controller datasets. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets a value indicating whether this Table was obtained as a result of joining a Table or a FeatureClass with another Table or FeatureClass from the same or different Datastore. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodCreates a virtual relationship class with the current table as the origin table/feature class and the destinationTable as the destination table/feature class. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodSearches and retrieves specific rows in this Table that satisfy the criteria set in the queryFilter. If no query filter is set, all rows will be retrieved. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodCreates a selection of specific rows in this Table that satisfy the criteria set in the queryFilter. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sorts data from this table or feature class. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Validate contingency constraints to distinguish between valid and invalid contingencies.
    Top
    Extension Methods
     NameDescription
    Public Extension Method Registers an extension id (guid) with the specified table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Public Extension Method Gets the readonly list of extension ids (guids) registered with the table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Public Extension Method Gets the CIMDataConnection for the specified dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Gets if the specified extension id (guid) is registered with the table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Public Extension Method Gets whether the dataset is a knowledge graph dataset or not. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Removes the extension id (guid) from being registered with the table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Top
