Quick tour of ArcPy
ArcPy is a Python site package that allows you to perform geographic data analysis, data conversion, data management, and map automation with Python.
When you use ArcGIS applications and scripts written using ArcPy, you can access and work with numerous Python modules developed by GIS professionals and programmers from many disciplines. The advantage of using ArcPy within Python is that Python is a general-purpose programming language. It is interpreted and dynamically typed, which allows you to quickly prototype and test scripts in an interactive environment while still allowing you to write large applications.
ArcPy provides access to geoprocessing tools as well as additional functions, classes, and modules that allow you to create simple or complex workflows. ArcPy is organized in tools, functions, classes, and modules.
Geoprocessing tools are functions available from arcpy—that is, they are accessed in the same way as any other Python function. However, to avoid confusion, a distinction is always made between tool and nontool functions (for example, utility functions such as ListFeatureClasses).
Tools are documented differently than functions. Every tool has a reference page in the help system. Functions are documented in the ArcPy documentation.
Tools return a
Resultobject; functions do not.Tools produce messages, which are accessed through a variety of functions such as
GetMessages. Functions do not produce messages.
Tool usage
The example below shows how to run the Buffer tool. When run in the Python window, the code will be transferred into the transcript section of the window along with the result.
arcpy.analysis.Buffer(r"c:\data\Portland.gdb\streets", r"c:\data\Portland.gdb\streets_buffer", "500 METERS")
The following is another example of running tools. It uses tools from the data management and conversion toolboxes. A field is added to the input streets feature class, the field is calculated, and the feature class is loaded into an enterprise geodatabase.
import arcpy
arcpy.management.AddField(r"c:\data\Portland.gdb\streets", "LENGTH_MILES", "FLOAT")
arcpy.management.CalculateField(r"c:\data\Portland.gdb\streets", "LENGTH_MILES", "!shape.length@miles!", "PYTHON3")
arcpy.conversion.FeatureClassToFeatureClass(r"c:\data\Portland.gdb\streets", "Database Connections/MySDE.sde/PortlandDataset", "streets")
Learn more about using tools in Python
Tool results
When a geoprocessing tool is run, the results of the tool are returned in a Result object. Typically, this object includes the path to the output dataset produced or updated by the tool. In other cases, it may contain additional values, such as a number or Boolean.
The following code examples show how return values are captured and what their values could be:
Return the path of the output feature class. The result can be used as input to another function.
result = arcpy.analysis.Buffer("rivers", "river_buffer", "50 METERS") # Prints C:\Portland\Portland_OR.gdb\river_buffer print(result) arcpy.analysis.Clip("streets", result, "streets_50m_of_rivers")Return the number of features.
result = arcpy.management.GetCount("streets_50m_of_rivers") # Prints 54 print(result[0])
Environment settings
Geoprocessing environment settings act as additional parameters that affect a tool's results. They differ from regular tool parameters in that they are separate from the tool and are interrogated and used by tools when they are run. Environment settings—such as an extent, the coordinate system of the output dataset, and the cell size of a new raster dataset—can all be specified and honored by the tools.
Environment settings are available from the env class as properties. These properties can be used to retrieve the current environment values and set them. The following are examples of how to use environment values:
Set the workspace environment.
arcpy.env.workspace = r"c:\data\Portland.gdb" arcpy.analysis.Buffer("streets", "street_buffer", "500 METERS")Get the current raster cell size setting and make sure it is a specific size for standard output.
if arcpy.env.cellSize != 30: arcpy.env.cellSize = 30
Learn more about using environment settings in Python
Functions
A function performs a specific task and can be incorporated into a larger program. In addition to tools, ArcPy exposes a number of functions to better support geoprocessing workflows. Functions can be used to list certain datasets, retrieve a dataset's properties, check for existence of data, validate a table name before adding it to a geodatabase, or perform many other useful scripting tasks.
The example code below shows getting data properties:
import arcpy
# Prints True
print(arcpy.Exists(r"c:\data\Portland.gdb\streets"))
# Prints NAD_1983_StatePlane_Oregon_North_FIPS_3601_Feet
sr = arcpy.Describe(r"c:\data\Portland.gdb\streets").spatialReference
print(sr.name)
Learn more about using functions in Python
Classes
ArcPy classes, such as the SpatialReference and Extent classes, are often used as shortcuts to complete geoprocessing tool parameters that would otherwise have a more complicated string equivalent. A class is analogous to an architectural blueprint. The blueprint provides the framework for how to create something. Classes can be used to create objects, which is often referred to as an instance.
import arcpy
spatial_ref = arcpy.SpatialReference("Hawaii Albers Equal Area Conic")
Learn more about using classes in Python
Modules
ArcPy is supported by a series of modules, including the following:
Charts (
arcpy.charts)Data Access (
arcpy.da)Geocoding (
arcpy.geocoding)Image Analysis (
arcpy.ia)Knowledge Graph (
arcpy.kg)Mapping (
arcpy.mp)Metadata (
arcpy.metadata)Network Analyst (
arcpy.naxandarcpy.na)Sharing (
arcpy.sharing)Spatial Analyst (
arcpy.sa)Utility Network (
arcpy.un)
For example, the tools of the arcpy.sa and arcpy.ia module use tools from the Spatial Analyst and Image Analyst toolboxes but are configured to support Map Algebra. For example, running arcpy.sa.Slope is the same as running the Slope tool from the Spatial Analyst toolbox.
