LastMileDeliveryResult
Summary
An object containing the results of a last mile delivery analysis that can be used to access outputs and solver messages.
Discussion
Instances of this class cannot be created directly. Instead, they are returned by the solve method of the LastMileDelivery class.
Learn more about how to use the result object to access and work with the analysis outputs
Properties
Name Explanation Data type
isPartialSolution
(Read only)
Returns True if the solver produced a partial solution, meaning that not all inputs were included in the results. This can occur if one of the inputs is unlocated and the solver class's ignoreInvalidLocations property is set to True.
Boolean
solveSucceeded
(Read only)
Returns True if the solve was successful.
Boolean
spatialReference
(Read only)
Returns the spatial reference of the output features. For example, feature classes created using the export method and geometry objects retrieved from the searchCursor method will have this spatial reference. The spatialReference value is typically the spatial reference of the network dataset or service used in the analysis.
SpatialReference
Methods
count(output_type)
Returns the number of rows for an output type.
output_type
The type of output features to count.
Set this parameter using the LastMileDeliveryOutputDataType enumeration.
Object
Return value
Data type Explanation
Integer
The number of rows.
export(output_type, output_features)
Exports the analysis results to a feature class or table.
The output features will be created in the spatial reference of the network dataset used for the analysis. If the arcpy.env.outputCoordinateSystem environment is set, the output features will be created with the specified coordinate system instead.
output_type
The type of output to export.
Learn more about the fields included in each output type
Object
output_features
The catalog path to the output feature class or table that will contain the exported features.
String
extent({output_type})
Returns the extent of the analysis output.
The method returns a RuntimeError exception if the analysis solve failed.
output_type
(Optional)
The type of output features for which to get the extent.
If you do not specify a value, or you specify a value of None, the extent for the combined analysis outputs is returned.
Object
Return value
Extent
An arcpy.Extent object indicating the extent of the designated output type.
fieldNames(output_type)
Returns a list of field names supported by a specified output type.
output_type
The type of output for which to return a list of field names.
Object
Return value
String
A list of field names supported by the specified output type.
saveAsLayerFile(file_name)
Saves the analysis result and settings to a network analysis layer package. The layer package can be opened in ArcGIS Pro as a record of the analysis settings or to visualize the results.
The method returns a RuntimeError exception if the allowSaveLayerFile property on the solver object is set to False.
file_name
The catalog path of the output layer package (.lpkx file).
Layer files with an .lyr extension are not supported for last mile delivery analyses.
String
saveRouteData(file_name)
Save the outputs from the analysis to a .zip file. The .zip file can be used to share the routes from the analysis as route layer items in ArcGIS Online or ArcGIS Enterprise using the Share As Route Layers tool.
A route layer item can be used by various applications, such as ArcGIS Navigator to provide route guidance for mobile workers, the Directions pane in Map Viewer Classic to further customize the route contained in the route layer, and ArcGIS Pro to create a route analysis layer from a route layer.
The output features will be created in the spatial reference of the network dataset used for analysis. If the arcpy.env.outputCoordinateSystem environment has been set, the output will be created in that spatial reference instead.
If the solve fails, saveRouteData returns a RuntimeError exception.
The method returns a RuntimeError exception if the allowSaveRouteData property on the solver object is set to False.
file_name
The full path of the output .zip file.
String
searchCursor(output_type, field_names[field_names,...], {where_clause})
Establishes a search cursor on the specified output type. This cursor can be used to read rows directly from the output.
output_type
The type of output that will be read.
Object
A list of field names of the output type whose values will be returned by the cursor. You can get the names of the fields supported by an output type using the fieldNames method.
In addition to regular fields, you can also access the geometry of the output using one of the following geometry tokens:
  • SHAPE@XY—A tuple of the feature's centroid's x- and y-coordinates.
  • SHAPE@XYZ—A tuple of the feature's centroid's x-, y-, and z-coordinates.
  • SHAPE@JSON—The Esri JSON string representing the geometry.
  • SHAPE@WKB—The well-known binary (WKB) representation for OGC geometry. It provides a portable representation of a geometry value as a contiguous stream of bytes.
  • SHAPE@WKT—The well-known text (WKT) representation for OGC geometry. It provides a portable representation of a geometry value as a text string.
  • SHAPE@—A geometry object for the feature.
The SHAPE@XY and SHAPE@XYZ tokens are only supported for point-based output types. The x-, y-, and z-values returned when using the SHAPE@XY and SHAPE@XYZ tokens are in the spatial reference reported by the solver result object's spatialReference property, and this is typically the same as the spatial reference of the network data source used for the analysis.
String
where_clause
(Optional)
An optional expression that limits the records returned. For more information on WHERE clauses and SQL statements, see SQL reference for query expressions used in ArcGIS.
The default value is None.
String
Return value
Object
A SolverResultSearchCursor object that reads rows from the output.
solverMessages(severity)
Get error, warning, and informational messages returned by the solver.
severity
The type of messages to be returned.
The parameter should be specified using the MessageSeverity enumeration.
Object
Return value
List
The messages are returned as a list of lists. The inner list contains two values; the first is a number representing the message code, and the second value is the message text.
An example of a list of messages returned from a failed origin destination cost matrix analysis.
[[-2147200995, '0 location(s) in "Destinations" are valid.  Need at least 1 valid location(s).'],
 [30024, 'Solve returned a failure.'],
 [-2147200995, 'Insufficient number of valid locations in "Origins" or "Destinations".']]
