Application settings
System administrators can manage many ArcGIS Pro user application settings.
The settings described below should be added under the Application element in the Pro.settingsConfig file.
UseLocalHelp
In the user interface, on the General tab on the Options dialog box, click Help Source to access the corresponding setting.
Learn more about the Help Source option
Possible values are the following:
  • true
  • false (default)
An example of this setting is shown below.
<UseLocalHelp isLocked="false">true</UseLocalHelp>
UseSpellCheck
In the user interface, on the Proofing tab on the Options dialog box, click Enable spell checking to access the corresponding setting.
Learn more about the Enable spell checking option
  • true (default)
  • false
<UseSpellCheck isLocked="false">true</UseSpellCheck>
UseDarkTheme
In the user interface, on the General tab on the Options dialog box, click Application Theme to access the corresponding setting.
Learn more about the Application Theme option
  • true
  • false (default)
<UseDarkTheme isLocked="false">true</UseDarkTheme>
ShiftContextMenus
In the user interface, on the User Interface tab on the Options dialog box, click the Context menus remember last selection check box to access the corresponding setting.
Learn more about the Context menus remember last selection check box
  • true (default)
  • false
<ShiftContextMenus isLocked="false">true</ShiftContextMenus>
UseSideBySideAddIns
In the user interface, on the Add-In Manager tab on the Settings page, click the Load add-ins side by side check box on the Options tab to access the corresponding setting.
Learn more about the Load add-ins side by side option
  • true (default)
  • false
<UseSideBySideAddIns isLocked="false">true</UseSideBySideAddIns>
CheckForAnnouncementsAtStartup
In the user interface, on the User Interface tab on the Options dialog box, click Notifications > Check for announcements on startup to access the corresponding setting.
Learn more about the Check for announcements on startup option
  • true (default)
  • false
<CheckForAnnouncementsAtStartup isLocked="false">true</CheckForAnnouncementsAtStartup>
ShowAnnouncementToastNotifications
In the user interface, on the User Interface tab on the Options dialog box, click Notifications > Show announcement toast notifications to access the corresponding setting.
Learn more about the Show announcement toast notifications option
  • true (default)
  • false
<ShowAnnouncementToastNotifications isLocked="false">true</ShowAnnouncementToastNotifications>
