Set general options
General options include settings for starting ArcGIS Pro, creating projects, repairing default project items, accessing the help system, setting the application theme, participating in the Esri User Experience Improvement program, and recovering projects.
Many options for starting ArcGIS Pro and creating projects require you to set paths. If you enter an invalid path, the input box displays an error. You cannot save any changes to settings on the page until the error is corrected.
Valid path settings may also display an error under some circumstances. For example, a valid network path is not recognized as such if you are disconnected from the network. When network connectivity is reestablished, the path is again recognized as valid; however, you are not able to save changes to the page in the meantime.
To set General options, follow these steps:
Open the ArcGIS Pro settings page in one of the following ways:
From an open project, click the Project tab on the ribbon.
From the start page, click the Settings tab
In the list of side tabs, click Options.
On the Options dialog box menu, under Application, click General.
Start ArcGIS Pro
Choose an option for how to start ArcGIS Pro:
Show the start page—ArcGIS Pro opens to the application start page. This is the default option.
Without a project template—ArcGIS Pro bypasses the start page and opens an unsaved, untitled project that contains no maps or scenes.
With a default project—ArcGIS Pro bypasses the start page and opens a specified project. Click Browse
and browse to a project, or enter a path in the Project text box.The project path can include Windows environment variables, such as
%APPDATA%and%USERPROFILE%.The default project can be a local project or a portal project.
Create projects
This section describes options for creating projects.
Software administrators can provide default values for new local project settings or new portal project settings and may prevent you from changing them.
On a local or network computer
This section describes options for creating projects on local or network computers.
Project location
Choose an option for where to save projects:
New projects are saved in the default location—New projects are saved to
%USERPROFILE%\Documents\ArcGIS\Projects. This is the default option.New projects are saved in a custom location—New projects are saved to a specified location. Enter a path in the Project location text box or click Browse
and browse to a folder. Optionally, browse to a location, click the New Item drop-down arrow, and create a folder
Both options allow you to browse to a different location on the New Project dialog box when you create a project.
Create a folder for the project
The Create a folder for the project check box specifies a default setting on the New Project dialog box. It does not enforce creating a folder for the project.
Choose whether to make folder creation a default setting:
Checked—A folder is created for new projects unless the setting is changed on the New Project dialog box. This is the default option.
Not checked—A folder is not created for new projects unless the setting is changed on the New Project dialog box.
If a folder is created for the project, it has the same name as the project, contains the project file (.aprx) and other default items, and is stored in the project location. If a folder is not created, the project file and default items are stored in the project location but not in a new folder.
Default Geodatabase
Choose an option to set the default geodatabase
for new projects:
New default geodatabase for each project—For each new project, a file geodatabase (
.gdb) is created as the default geodatabase. This is the default option.Same default geodatabase for all projects—Each new project uses the same default geodatabase. Enter a path in the Default Geodatabase text box or click Browse
and browse to a geodatabase. Optionally, browse to a location, click the New Item drop-down arrow, and create a geodatabase
or database connection
When a default geodatabase is created for each project, the geodatabase is a file geodatabase. When the same default geodatabase is used for all projects, the geodatabase can be a file geodatabase (.gdb), mobile geodatabase (.geodatabase), or enterprise geodatabase (.sde). You can change the default geodatabase for a project after the project is created.
Default Toolbox
Choose an option to set the default toolbox
for new projects:
New default toolbox for each project—For each new project, a toolbox (
.atbx) is created as the default toolbox. This is the default option.Same default toolbox for all projects—Each new project uses the same default toolbox. Enter a path in the Default Toolbox text box or click Browse
and browse to a toolbox. Optionally, browse to a location, click the New Item drop-down arrow, and create a toolbox
(.atbx).
When the same default toolbox is used, you can choose a toolbox (.atbx), a Python toolbox (.pyt), or a legacy toolbox (.tbx). A toolbox stored in a geodatabase cannot be the default toolbox. You can change the default toolbox for a project after the project is created.
On an ArcGIS Enterprise portal
This section describes options for creating projects on an ArcGIS Enterprise portal. Portal projects, unlike local projects, do not, by default, create a geodatabase and toolbox for the project.
Paths set here become the defaults for all new portal projects. No paths are preset other than the project download location. Optionally, if the paths on this dialog box are empty, you can populate them with the paths you set in a new portal project.
Download location
Portal projects are downloaded to the location set in the Download location text box. This is where the local copy of the portal project is stored.
Set a location:
Accept the default download location of
%USERPROFILE%\Documents\ArcGIS\OnlineProjects.Alternatively, click Browse
and browse to a location or enter a path in the Download location text box. On the browse dialog box, you can also click the New Item drop-down arrow and create a folder
If the download location is on a network share, specify a unique path (for example, by including the %USERNAME% environment variable). Otherwise, you and other users will overwrite each other's local copies of the project.
Home folder
The portal project home folder
is the default location for output files that are not saved to a geodatabase.
Enter a path in the Home folder text box or click Browse
and browse to a folder.Optionally, browse to a location, click the New Item drop-down arrow, and create a folder
Default Geodatabase
The portal project default geodatabase
is the default location for geoprocessing output files.
and browse to a geodatabase.Optionally, browse to a location, click the New Item drop-down arrow, and create a geodatabase
Default Toolbox
The portal project default toolbox
is the default location for geoprocessing models and scripts. You must use a toolbox (.atbx). You cannot use a Python toolbox (.pyt) or a legacy toolbox (.tbx) as the default toolbox in a portal project. In addition, a toolbox stored in a geodatabase cannot be the default toolbox.
and browse to a toolbox.Optionally, browse to a location, click the New Item drop-down arrow, and create a toolbox
(.atbx).
Wizard
When a portal project is created from the start page or the New page of the ArcGIS Pro settings, a wizard opens to guide you through the project configuration. You can turn the wizard off to create portal projects from a dialog box instead.
To stop using the wizard, uncheck the Use the wizard to create a portal project check box. To start using the wizard again, check the box.
Save changes to a portal project
When you save changes to a portal project, you may need to resolve conflicts with changes made by other users. During the conflict resolution process, the project is locked and no one can save changes to the portal. After some time, a save cancellation message appears to remind you to complete the process. You can click OK on the message to continue resolving conflicts. If you do not click OK while the message remains visible, your save is canceled and the project is unlocked.
When resolving conflicts:
Save cancellation message appears after (seconds)—The default value is 300. The minimum value is 10 and the maximum value is 3,000. Only integers are accepted.
Save cancellation message remains visible for (seconds)—The default value is 60. The minimum value is 10 and the maximum value is 3,000. Only integers are accepted.
ArcGIS Pro maintains a number of saved local copies of the portal project in addition to your working local copy. These saved copies can be used to overwrite the portal project if necessary. You can specify the location of these saved copies and the number of copies to save.
Local copies are saved for each portal project. This means that if the number of local copies to save is 3, three copies of Project A, three copies of Project B, and so on, are kept in the designated location. These copies are not deleted automatically. To manage disk space, it is recommended that you delete them manually for projects that are no longer in use.
Enter a path in the Location of saved local copies text box or click Browse
and browse to a folder. The default path is %LOCALAPPDATA%\ESRI\ArcGISPro\PublishedProjects.Enter a value in the Number of local copies to save text box—The default value is 3. The minimum value is 0 and the maximum value is 50.
If multiple users set the location of their saved local copies to the same shared drive, the number of saved local copies (for example, 3) is maintained, but the copies may be owned by different users. For example, Copy 1 may be saved by User A, Copy 2 by User B, and Copy 3 by User C. Multiple saved copies for each user are not maintained unless an appropriate environment variable, such as %USERNAME%, is included in the path.
Repair Project Items
Every project must have a home folder, default geodatabase, and default toolbox. If you open a project in which one of these required items can't be accessed, ArcGIS Pro can create a new default item for you. Alternatively, you can specify an existing item to be the default item or create a new default item yourself.
A default item may become inaccessible for various reasons. For example, it may be deleted, moved, or renamed, or its containing folder may be deleted, moved, or renamed. If the item is on a network share, the network may be unavailable.
Learn more about repairing default project items
Home Folder Handling
Choose an option for repairing a home folder:
Automatically create a new home folder (default)—ArcGIS Pro creates a new home folder. When possible, the new folder has the same name and location as the previous home folder.
Prompt to specify a different home folder—Browse to an existing folder or create a folder to use as the new home folder.
Default Geodatabase Handling
Choose an option for repairing a default geodatabase:
Automatically create a new default geodatabase (default)—ArcGIS Pro creates a new geodatabase of the same type (
.gdbor.geodatabaseonly) as the previous default geodatabase. When possible, it uses the same name and location.Prompt to specify a different geodatabase—Browse to an existing geodatabase or create a geodatabase to use as the new default geodatabase.
Enterprise geodatabases (.sde) cannot be repaired automatically. If an enterprise geodatabase is an inaccessible project default item, and the handling option is set to automatically create a new item, an error message appears. When the project opens, the inaccessible item is displayed as the default item, but its path is broken. You may be able to repair the item manually.
Default Toolbox Handling
Choose an option for repairing a default toolbox:
Automatically create a new default toolbox (default)—ArcGIS Pro creates a new toolbox of the same type (
.atbxor.pytonly) as the previous default toolbox. When possible, it uses the same name and location.Prompt to specify a different toolbox—Browse to an existing toolbox or create a toolbox to use as the new default toolbox.
Legacy toolboxes (.tbx) cannot be repaired automatically. If a legacy toolbox is an inaccessible default item, and the handling option is set to automatically create a new item, an error message appears. When the project opens, the inaccessible item is displayed as the default item, but its path is broken. You may be able to repair the item manually.
Help source
ArcGIS Pro has an online help system and an offline (installed) help system. For the most part, the two systems have the same content; however, the online help may be more current. For more information, see Access the help.
Choose a help source option:
Online help from the Internet—The ArcGIS Pro help system opens in your default web browser. This is the default option.
Offline help from your computer (requires ArcGIS Documentation Center)—ArcGIS Pro opens offline help from ArcGIS Documentation Center, an application that you download from My Esri and install on the same computer as ArcGIS Pro. Once ArcGIS Documentation Center is installed, you can download the documentation set for your version of ArcGIS Pro, in the supported language you choose. Offline help is displayed in your default browser using a local host.
Tip:
If you work in the field or in a disconnected environment, download and install the offline help system.
Application Theme
ArcGIS Pro has two color themes. If you switch themes, you must restart ArcGIS Pro for the change to take effect.
Choose an application theme:
Light—The application background color is light gray. This is the default option.
Dark—The application background color is black.
Application Reporting
Application reporting options allow you to choose whether to participate in the Esri User Experience Improvement (EUEI) program and report errors to Esri, and to specify the geographic region to which EUEI and error report information is sent.
Reporting Region
EUEI data and error reports are uploaded to a cloud storage region of your choice.
Accept the North America (default) setting or click the Reporting Region drop-down arrow and choose a different region.
Esri User Experience Improvement program (EUEI)
The Esri User Experience Improvement (EUEI) program helps Esri improve the interface and usability of ArcGIS Pro.
Choose whether to participate in the EUEI program:
To participate, check the Anonymously participate in the design of future versions of ArcGIS check box. This is the default.
If you do not want to participate, uncheck the Anonymously participate in the design of future versions of ArcGIS check box.
Participation doesn't require action on your part other than consent. You can change your decision at any time.
Error Reporting
If ArcGIS Pro or another ArcGIS application closes unexpectedly, a dialog box appears that allows you to send an error report to Esri. It is recommended that you send error reports because they may contain information about problems such as hardware limitations, memory leaks, or compatibility issues with third-party software that are otherwise hard to diagnose. All reports are analyzed.
Choose whether to submit error reports to Esri:
To submit reports, check the Submit error reports to Esri check box. This is the default.
If you do not want to submit reports, uncheck the Submit error reports to Esri check box.
Project Recovery
The Create a backup when the project has unsaved changes check box specifies whether backup copies of your project are made as you work. A backup copy allows you to recover your project if ArcGIS Pro shuts down unexpectedly.
Software administrators can provide default values for project recovery settings and may prevent you from changing them.
Choose whether to create backup copies of your project:
Checked—A backup copy is made at a specified interval. This is the default option.
Not checked—A backup copy is not made.
The value in the Save a backup after this time interval has elapsed text box specifies how often, in minutes, a backup copy is made. The default value is 5. You can enter an integer from 1 to 999.
