Project settings
System administrators can manage many ArcGIS Pro user application settings.
The settings below should be added under the Projects element in the Pro.settingsConfig file.
You can use Windows environment variables in paths. For example, %USERNAME% inserts the name of the current user, and %APPDATA% inserts the path to the AppData folder on the local computer.
CreateBackup
In the user interface, on the General tab on the Options dialog box, click Project Recovery > Create a backup when the project has unsaved changes to access the corresponding setting.
Learn more about backup options
Possible values are the following:
  • true (default)
  • false
An example of this setting is shown below.
<CreateBackup isLocked="true">true</CreateBackup>
BackupIntervalMinutes
In the user interface, on the General tab on the Options dialog box, click Project Recovery > Save a backup after this time interval has elapsed to access the corresponding setting. Use this setting with the CreateBackup setting.
Learn more about backup interval options
  • A positive integer representing minutes. The default value is 5.
The minimum value is 1 and the maximum value is 999.
<BackupIntervalMinutes isLocked="true">3</BackupIntervalMinutes>
CreatePortalProjects
The CreatePortalProjects setting controls whether users can create portal projects on an ArcGIS Enterprise portal. This setting does not have a corresponding user interface setting.
  • true (default)
  • false
If isLocked="true" and the value is false, new projects can only be created in local and network folders, and local projects cannot be saved as portal projects. However, users can open, update, and save existing portal projects.
<CreatePortalProjects isLocked="true">false</CreatePortalProjects>
Local project settings
Add the following settings under the LocalProject element in the Pro.settingsConfig file.
Learn more about options for creating projects on a local or network computer
CustomDefaultLocation
In the user interface, on the General tab on the Options dialog box, click Create projects > On a local or network computer > Project location to access the corresponding setting.
  • A valid folder path. The default value is %USERPROFILE%\Documents\ArcGIS\Projects.
The default setting is to save new projects in the default location.
If isLocked="false" and a path is specified, the path appears as a suggestion in the New projects are saved in a custom location input box on the Options dialog box. However, the default setting is not changed.
<LocalProject>
  <CustomDefaultLocation isLocked="true">\\dataserver1\TeamDefaults\Projects</CustomDefaultLocation>
</LocalProject>
CreateProjectInNewFolder
In the user interface, the General tab on the Options dialog box, click Create projects > On a local or network computer > Project location > Create a folder for the project to access the corresponding setting.
This setting also appears in the user interface on the New Project dialog box.
  • true (default)
  • false
<LocalProject>
  <CreateProjectInNewFolder isLocked="true">false</CreateProjectInNewFolder>
</LocalProject>
HomeFolder
In the user interface, on the Current Settings tab on the Options dialog box, click Home folder to access the corresponding setting.
  • A valid folder path. The default value is the path to the folder that contains the project file.
<LocalProject>
  <HomeFolder isLocked="true">\\dataserver1\TeamDefaults\Output</HomeFolder>
</LocalProject>
DefaultGeodatabase
In the user interface, on the General tab on the Options dialog box, click Create projects > On a local or network computer > Default Geodatabase to access the corresponding setting.
  • A valid folder path to a file, mobile, or enterprise geodatabase
The default setting is to create a new default geodatabase for each project.
If isLocked="false" and a path is specified, the path appears as a suggestion in the Same default geodatabase for all projects input box on the Options dialog box. However, the default setting is not changed.
<LocalProject>
  <DefaultGeodatabase isLocked="true">\\dataserver1\TeamDefaults\Data\TeamData.sde</DefaultGeodatabase>
</LocalProject>
DefaultToolbox
In the user interface, on the General tab on the Options dialog box, click Create projects > On a local or network computer > Default Toolbox to access the corresponding setting.
  • A valid folder path to a toolbox (.atbx), Python toolbox (.pyt), or legacy toolbox (.tbx)
The default setting is to create a new ArcGIS toolbox (.atbx) for each project.
If isLocked="false" and a path is specified, the path appears as a suggestion in the Same default toolbox for all projects input box on the Options dialog box. However, the default setting is not changed.
<LocalProject>
  <DefaultToolbox isLocked="true">\\dataserver1\TeamDefaults\Tools\TeamTools.atbx</DefaultToolbox>
</LocalProject>
Portal project settings
Add the following settings under the PortalProject element in the Pro.settingsConfig file.
Learn more about options for creating projects on an ArcGIS Enterprise portal
LocalCacheLocation
In the user interface, on the General tab on the Options dialog box, click Create projects > On an ArcGIS Enterprise portal > Download location to access the corresponding setting.
  • A valid folder path. The default value is %USERPROFILE%\Documents\ArcGIS\OnlineProjects.
<PortalProject>
  <LocalCacheLocation isLocked="true">C:\PortalProjectCache</LocalCacheLocation>
</PortalProject>
HomeFolder
In the user interface, on the General tab on the Options dialog box, click Create projects > On an ArcGIS Enterprise portal > Home folder to access the corresponding setting.
  • A valid folder path. There is no default value.
<PortalProject>
  <HomeFolder isLocked="true">\\dataserver2\TeamHome</HomeFolder>
</PortalProject>
DefaultGeodatabase
In the user interface, on the General tab on the Options dialog box, click Create projects > On an ArcGIS Enterprise portal > Default Geodatabase to access the corresponding setting.
  • A valid folder path to a file, mobile, or enterprise geodatabase. There is no default value.
<PortalProject>
  <DefaultGeodatabase isLocked="true">\\dataserver2\TeamHome\TeamData.sde</DefaultGeodatabase>
</PortalProject>
DefaultToolbox
In the user interface, on the General tab on the Options dialog box, click Create projects > On an ArcGIS Enterprise portal > Default Toolbox to access the corresponding setting.
  • A valid folder path to an ArcGIS toolbox (.atbx). There is no default value.
Other toolbox types are not allowed.
<PortalProject>
  <DefaultToolbox isLocked="true">\\dataserver2\TeamHome\TeamTools.atbx</DefaultToolbox>
</PortalProject>
ConflictsDialogOpenTimerDuration
This setting specifies the number of seconds that the Project Conflicts dialog box can be idle before a prompt to continue working appears.
In the user interface, on the General tab on the Options dialog box, click Create projects > On an ArcGIS Enterprise portal > Save changes to a portal project > Save cancellation messge appears after (seconds) to access the corresponding setting.
Learn more about project conflicts
  • A positive integer representing seconds. The default value is 300.
The minimum value is 10 and the maximum value is 3000.
<PortalProject>
  <ConflictsDialogOpenTimerDuration isLocked="true">300</ConflictsDialogOpenTimerDuration>
</PortalProject>
ConflictsDialogWarningMessageTimerDuration
This setting specifies the number of seconds for which a prompt to continue working displays after it appears on an idle Project Conflicts dialog box.
In the user interface, on the General tab on the Options dialog box, click Create projects > On an ArcGIS Enterprise portal > Save changes to a portal project > Save cancellation messge remains visible for (seconds) to access the corresponding setting.
  • A positive integer representing seconds. The default value is 60.
If the user clicks OK on the prompt to continue working, the Project Conflicts dialog box remains open and the timer resets. Otherwise, the Project Conflicts dialog box closes and a message that the save was canceled appears.
<PortalProject>
  <ConflictsDialogWarningMessageTimerDuration isLocked="true">60</ConflictsDialogWarningMessageTimerDuration>
</PortalProject>
SavePointsLocation
This setting specifies the path to the automatically saved copies of a portal project that are stored by default on each user's computer. These copies exist in addition to the local copy in the user's download location. They can be used to overwrite a portal project if it needs to be restored to an earlier state.
In the user interface, on the General tab on the Options dialog box, click Create projects > On an ArcGIS Enterprise portal > Save changes to a portal project > Location of saved local copies to access the corresponding setting.
  • A valid folder path. The default value is %USERPROFILE%\AppData\Local\ESRI\ArcGISPro\PublishedProjects.
<PortalProject>
  <SavePointsLocation isLocked="true">\\dataserver2\TeamHome\ProjectSavePoints\%USERNAME%</SavePointsLocation>
</PortalProject>
SaveProProjectLimit
This setting specifies the number of automatically saved copies of a portal project that are stored. These copies exist in addition to the local copy in each user's download location.
In the user interface, on the General tab on the Options dialog box, click Create projects > On an ArcGIS Enterprise portal > Save changes to a portal project > Number of local copies to save to access the corresponding setting.
Learn more about saved local copies
  • Zero or a positive integer representing the number of automatically saved copies. The default value is 3.
The minimum value is 0 and the maximum value is 50.
The value applies to each unique location specified in the SavePointsLocation setting. For example, if the value is 3 and the default SavePointsLocation path is used, each user has three saved copies of the project in their PublishedProjects folder. Each copy is a recent state of the project as saved by that user.
If a shared location is used, three copies are saved in total. These copies are the three most recent states of the project as saved by any user. In this situation, a user who needs to overwrite a portal project can access any of the three copies, regardless of which user saved them. The user's own saves may or may not be among the available copies.
<PortalProject>
  <SaveProProjectLimit isLocked="true">3</SaveProProjectLimit>
</PortalProject>
