Set user interface options
User interface options allow you to control various aspects of the ArcGIS Pro user interface to improve productivity and make the application easier to use.
To set the User Interface options, do the following:
Open the ArcGIS Pro settings page in one of the following ways:
From an open project, click the Project tab on the ribbon.
From the start page, click the Settings tab
In the list of side tabs, click Options.
On the Options dialog box, under Application, click User Interface.
General
General user interface options allow you to set behavior for context menus and Undo and Redo operations.
Context menus remember last selection
When the Context menus remember last selection check box is checked, the last command you ran on a context menu is automatically selected the next time you open the menu. This is the default setting. When the box is unchecked, no command is selected when you open a context menu.
The functionality does not apply to commands that are nested on a context menu, such as Selection > Pan To Selection.
Keep current ribbon tab active when switching views
When the Keep current ribbon tab active when switching views check box is checked, the ribbon tab does not change when you switch views, as long as the tab is available for the view you switch to. When the box is unchecked (the default), the ribbon tab changes to the default tab of the view you switch to or the tab that was active when you last used the view.
For example, suppose a map view is active and you click the View tab on the ribbon and open a catalog view. If the box is checked, the View tab remains active. If the box is not checked, the Catalog tab becomes active, because this is the default ribbon tab for catalog views.
The Keep current ribbon tab active when switching views option is especially useful when you have a custom tab with tools that are used in most of your workflows and you want this tab to remain active during your session.
This option works with the main ribbon tabs, but not contextual tabs such as Feature Layer, Data, and Time.
Remember Undo and Redo filters
On the Quick Access Toolbar, you can filter Undo and Redo commands to group actions by functional category or to show only actions that belong to a specific category.
When the Remember Undo and Redo filters check box is unchecked, these filter settings are not persisted from one ArcGIS Pro session to the next. This is the default. When the box is checked, the settings are persisted between sessions.
Show keyboard shortcuts in context menus when available
When the Show keyboard shortcuts in context menus when available check box is checked, shortcuts appear next to context menu commands when available. This is the default setting. When the box is unchecked, shortcuts do not appear on context menus.
Use animated flashing effects for interactive tools
When the Use animated flashing effects for interactive tools check box is checked, using some interactive tools creates a flashing effect. This is the default setting. When the box is unchecked, no flashing effect is used.
Ease of access
You can scale the size of the text, icons, and other parts of the ArcGIS Pro user interface by 50 to 200 percent. The content of map, scene, and layout views does not scale correspondingly. Use navigation and zoom tools to scale the content in those views.
To increase or decrease the size of the ArcGIS Pro user interface, complete the following steps:
Click the User interface scaling drop-down arrow and choose a scale value.
Click OK.
Restart ArcGIS Pro.
Notifications
Notifications options allow you to play a sound when notifications are received, and to choose whether software announcements are received and how they are displayed.
Allow notifications to play sounds
When the Allow notifications to play sounds check box is unchecked, toast notifications are silent. This is the default setting. When the box is checked, a sound plays when a toast notification appears.
Check for announcements on startup
When the box is checked, ArcGIS Pro checks for software announcements on application startup. This is the default setting. When the box is unchecked, ArcGIS Pro does not check for announcements.
Show announcement toast notifications
When the box is checked, announcements appear both as toast notifications and notifications in the Notifications pane. This is the default setting. When the box is unchecked, announcements appear in the Notifications pane and on the user interface when you update ArcGIS Pro.
Set default options for working with views
To set the default position of the first table, chart, video, ModelBuilder, or notebook view opened in a project, choose from the following options:
Docked below the active map—This is the default setting for table, chart, and video views.
Stacked on top of the active view—This is the default setting for ModelBuilder and notebook views.
As a separate floating window—The view opens in a new floating window. By default, additional views of the same type are stacked in the same window. To open each view in a new window, uncheck the Stack additional views on top of the last active view check box.
