Types of raster charts
In ArcGIS Pro, you can create the charts described below that visualize various characteristics and relationships in raster data.
Visualize change over time or distance
Chart |
Description |
Use temporal profiles to visualize change over time for variables, bands, or values from other dimensions simultaneously. |
Use dimension profiles to visualize change along a vertical dimension, such as depth or height, using a multidimensional raster dataset with a z-dimension. |
Use surface profiles to visualize change in values, such as elevation or surface temperature, over distance. |
Use the Pixel Time Series Change Explorer to model CCDC or LandTrendR results for individual pixels in a multidimensional raster. |
Analyze the spectral signature of different features in imagery
Chart |
Description |
Use spectral profiles to select areas of interest or ground features on the image and review the spectral information for all bands. |
Visualize distributions and frequency
Chart |
Description |
Use image histograms to visualize the distribution of pixel values for a band by grouping the image's dynamic range into bins and measuring the frequency of those groups. |
Visualize distributions in categorical data
Chart |
Description |
Use image bar charts to visualize and compare the distribution of categorical data in thematic raster datasets. |
