Utilities
ModelBuilder supports utilities with advanced behavior. Add a utility to a model by clicking ModelBuilder > Insert > Utilities, and then select the utility.
Utility
Calculate Value
Returns a value based on a specified Python or ArcGIS Arcade expression.
Collect Values
Collects output values from an iterator or converts a list of values into a single input with multiple values.
Custom Message
Adds custom error, warning, or informative messages to a model's messages to enhance the context of a model when run.
Get Field Value
Returns the value of the first row of a table for the specified field.
Parse Path
Parses an input into its file name, extension, path, and the last workspace name. The output can be used as an inline variable in the output name of other tools.
Select Data
Selects data in a parent data element such as a folder, geodatabase, or feature dataset.
