Raster analysis with the Spatial Analyst extension
Available with the Spatial Analyst license.
The ArcGIS Spatial Analyst extension provides a broad range of spatial modeling and analysis capabilities.
Some of these capabilities require additional components to be installed into ArcGIS Pro. The following sections describe the components and how to install them.
Solar analysis
You can perform solar radiation analysis for a landscape or for specific locations with the Spatial Analyst extension. The tools allow you to map and analyze the effects of the sun over a geographic area for specific time periods. Certain tools in ArcGIS Pro can perform solar analysis on different bodies in the solar system other than the Earth.
The following tools support analysis on the Earth, Moon, and the planet Mars:
  • The Feature Solar Radiation tool calculates the incoming solar insolation for input points or polygon features relative to the surface on the Earth or Moon.
  • The Raster Solar Radiation tool calculates the incoming solar insolation for every raster cell of a digital surface model for the Earth or Moon.
To perform this type of analysis on Mars, these tools require additional components to be installed and configured.
Installation
To take advantage of the capabilities, you need to run a setup installer to update ArcGIS Pro with the necessary components. The installer will put additional files required by the Spatial Analyst extension into system directories.
See Install Raster Analysis Supplemental Files (RASF) for the download location and instructions.
