Use Raster Analysis Supplemental Files (RASF)
Available with the Spatial Analyst license.
Certain types of solar analysis can be performed on Earth, as well as on the Moon and the planet Mars. For space science, one application of this capability is plotting out potential exploration missions for solar-powered rovers.
To perform this type of analysis on Mars, the two primary tools, Feature Solar Radiation and Raster Solar Radiation, require the the installation of additional files into ArcGIS Pro. The files include SPICE kernels and related resources used for planetary ephemeris calculations, enabling Solar Radiation analysis and Mars-specific planetary workflows.
These files are not installed with ArcGIS Pro. They are included in the Raster Analysis Supplemental Files (RASF) software component, which you can download from My Esri and install on each machine where ArcGIS Pro is installed.
This installer is only required if you plan to run Solar Analysis with Mars data. It is not necessary for analysis on the Earth or Moon.
Download permission is typically restricted to software administrators or a small number of designated people in an organization. You will not see a Downloads tab in My Esri unless you have permission.
Install the files
To install the files, first, sign in to My Esri, and complete the following steps:
  1. In the Downloads > ArcGIS Pro section of My Esri, locate and download the ArcGIS Raster Analysis Supplemental Files (RASF) installation. An executable file (.exe) is downloaded to your computer.
  2. Browse to the location where you placed the executable file, and double-click it to start the installation process.
  3. Accept the destination folder to which files are extracted, or click Browse to select a different destination. The default destination folder for the files is <System Drive>\Users\<username>\Documents\ArcGIS <version>\ProRASF
  4. Click Next.
    A message indicates when the files have been successfully extracted, and the Launch the setup program check box is checked by default.
    To install the software later, uncheck the Launch the setup program check box, and click Close. When you're ready to install, browse to the folder in the destination you specified in the previous step.
  5. Click Close.
  6. In the Welcome to the ArcGIS Raster Analysis Supplemental Files (RASF) Setup program window, click Next.
  7. Review the license agreement, click the option to accept the agreement, and click Next.
  8. Click Install.
  9. When the installation is complete, click Finish.
Once the installation process is finished and ArcGIS Pro has been restarted, you can begin using the updated tools.
