Privileges for using ArcGIS with a SQL Server database
Privileges determine what a user is authorized to do with the data and the database. Assign privileges based on the type of work the person does in the organization.
As a Microsoft SQL Server database administrator, you create roles based on what users need to do in the database, grant privileges to the roles, and add the appropriate user accounts to each role. The minimum required privileges for common types of users for which you would create roles are listed below: data viewers, data editors, and data creators.
These privileges apply to using ArcGIS with a SQL Server database or one of the supported SQL Server database service offerings. If you need to know the privileges required to use a geodatabase, see Privileges for geodatabases in SQL Server.
The following table lists three groups of users and the minimum privileges they require to query, edit, or create data from ArcGIS:
Type of user |
Required privileges |
Purpose |
Data viewer |
This privilege allows users to connect to the database. The |
Data viewers must have the If allowed to read all tables in the database, you can assign users to the db_datareader database role; otherwise, grant |
Data editor Data editors require the same privileges as data viewers, as well as these additional privileges. |
Grant the editing operations you want editors to perform on specific tables. You can grant any combination of |
Data creator |
Each user must own or have Schema names must match individual usernames. You cannot use a single schema for all data creators. For example, the username ruth must own or control a schema named ruth. If this requirement is not met, the user cannot use ArcGIS to create objects in the database, and objects created outside of ArcGIS may not be accessible from ArcGIS clients. |
These privileges allow data creators to create tables and feature classes. |
To edit data, publish editable web feature layers that reference the data in your SQL Server database.
If data creators at your site need to create views, grant them the CREATE VIEW permission. If you require that data creators be able to delete the objects they create, grant them the following additional privileges:
DROP VIEWDROP TABLEDROP INDEX
