Introduction to locator properties and options
When a locator is created, default parameters of the geocoding properties and options are saved in the locator. The geocoding properties and options control how the locator finds and filters the list of candidates, how it places the locations of matched addresses, the information that's contained in the geocoding output, and how geocoding performance is optimized. These geocoding properties can be set to meet specific use-case requirements.
To modify the locator's settings, it must be either added to the project or accessed from a folder connection
in the Catalog pane under the Folders category
Learn more about adjusting the performance of your geocoding experience.
Learn more about adjusting the quality of your geocoding experience.
Access the locator properties
Right-click the locator you want to modify in the Locators folder or in a folder connection in the Catalog pane, and click Locator Properties to open the Locator Properties dialog box.
ArcGIS Pro only supports accessing and modifying locator properties for locators that are stored in a file location. Accessing or modifying locator properties for portal locators and server locators is not currently supported.
