Address elements
Reference data is one of the key elements in a locator. Knowing which address elements are needed for the locator role used to create the locator is key to formatting the reference data.
Formatting the reference data
The elements described below are used to format reference data. The Split Address Into Components geoprocessing tool can be used to help format the street address information in the reference data by parsing the street address into multiple fields for each address component. If you find that street addresses were not split in the manner you expected, you can review split address components and make modifications using the Split Address Review pane.
Address elements
ArcGIS Pro includes several predefined locator roles that have specific requirements for the primary reference data it can use to match addresses. You can use data from your organization or from other data providers, but they each contain some common address elements that are required to build a locator. These address elements must be divided into multiple fields in the attribute table of the reference data. Common address elements and their descriptions are shown in the following table:
Element
Left house number range
A low number and a high number of the address range for the left side of the street, such as 100, 198
Right house number range
A low number and a high number of the address range for the right side of the street, such as 101, 199
Building name
The building name associated with an address. An address can have both a building name and a house number.
Left parity
The odd, even, or mixed house number range value on the left side of the street, such as O, E, or B
Right parity
The odd, even, or mixed house number range value on the right side of the street, such as O, E, or B
Side
The left or right side of the street where an address resides relative to the direction of feature digitization, such as L or R
Prefix direction
A direction that precedes the street name, such as the W in W. Redlands Blvd.
Prefix type
A street type that precedes the street name, such as Avenue in Avenue B
Street name
The name of the street, such as Cherry in Cherry Rd.
Suffix type
A street type that follows the street name, such as St. in New York St.
Suffix direction
A direction that follows the street name, such as NW in Bridge St. NW
Wing name
The wing ID that follows the wing type, which is part of a building, such as A in Wing A.
Wing type
The wing subunit classification that follows the room name, such as Wing in Wing A.
Room name
The room ID that follows the room type, such as 102 in Room 102.
Room type
The room subunit classification that follows the unit name, such as Room in Room 102.
Unit name
A subaddress unit ID that follows the unit type, such as 2C in Orange St., Suite 2C
Unit type
A subaddress unit type that follows the street name, such as Apt. in Gilman Ave., Apt. 17
Level name
A floor subunit ID that follows the level type, such as 3 in Level 3
Level type
A floor subunit classification that follows the building name, such as Floor in Building C, Floor 3
Building unit
A building subunit ID that follows the building type, such as 14 in Building 14
Building type
A building subunit classification that follows the street name, such as Bldg. in Orchard Ct., Bldg. F
Neighborhood
A subsection of a city or district, such as Little Italy
City name
A city name, such as Olympia
County
A county name, such as San Bernardino County.
Use the full county name, such as San Bernardino County instead of the short name of San Bernardino, which can be both the city name or the county name.
State
A state name or its abbreviation, such as Washington or WA
ZIP Code
The postal codes used by the United States Postal Service, such as 98501
ZIP Code extension
The postal codes with an additional extension used by the United States Postal Service ZIP+4 , such as 90210-3841
Country
A three-character code for a country, such as USA
Language
A three-character language code, representing the language of the address, such as ENG
Learn more about each locator role provided with ArcGIS Pro and the requirements for reference data
