Locator role fields
Each locator role has fields that are used to store the information that is necessary for searching and displaying geocoding results. The following table of these fields includes additional information about what they are used for, such as whether the field is used during the search process, for display purposes only, for displaying results on the map, or for prioritizing similar matches.
Some role fields may not be available for every supported country in the Create Locator tool. For example, District is a role field that is supported for Sweden, but not for the United States.
Tip:
For the reference data fields to be automatically assigned to the locator role fields in the Create Locator tool, the field alias names in the reference data must match the field names that are displayed in the Field Mapping parameter of the Create Locator tool.
Locator role field usage
Field name
Used for search
Feature ID
ID field used to collapse duplicate features in the reference data for each primary locator role.
Assigning the ObjectID field in the reference data to the Feature ID role field when building the locator can cause the locator build time to increase and can affect the quality of the geocode results.
Place Join ID
JoinID used to link alternate place-names and alternate categories for a point of interest (POI) locator.
Place Name
Used for search
The formal name of a geocode match candidate, such as Paris or Starbucks.
Place Category
Used for search
The high-level category associated with a place, such as Food or Education.
Geocoding results can be filtered by these values.
Place Subcategory
Used for search
The lower-level category associated with a place, such as American food for the Food category or College for the Education category.
Address Join ID
JoinID to link alternate house numbers.
House Number
Used for search
The house number associated with an address. House Number, House Number From, and House Number To or Building Name is required for the Point Address role.
House Number From
Used for search
A value representing the beginning number of a range. It is not always the smallest number in the range. House Number, House Number From, and House Number To, or Building Name is required for the Point Address role.
Left House Number From and Right House Number From are required for the Street Address role.
House Number To
Used for search
A value representing the ending number of a range. It is not always the largest number in the range. House Number, House Number From, and House Number To, or Building Name is required.
Left House Number To and Right House Number To are required for the Street Address role.
Parity
The parity of the house number range. The supported values are Not applicable, NA, N/A, 0, D, Default, Z, Zero; Even, E, 1; Odd, O, 2; Mixed, M, Both, B, and 3.
  • When Even is specified, only even numbered house numbers will match to the record.
  • When Odd is specified, only odd numbered house numbers will match to the record.
  • If Mixed or Both are specified, all house numbers in the range will match for the record.
Distance
Used for search
This is the input field used with the Distance Marker role to specify distance values for each distance marker. This is not the same as the distance output field, which indicates how far the result is from the location that is passed in when geocoding.
Distance From
Used for search
A value representing the beginning number of a distance range. It is not always the smallest number in the range. This value is at the starting point of the digitized line.
Distance To
Used for search
A value representing the ending number of a distance range. It is not always the largest number in the range. This value is at the end point of the digitized line.
Distance Unit
Used for search
The distance unit associated with the distance value. The supported values are KM, Kilometers, MI, Miles, M, and Meters.
Building Name
Used for search
The building name associated with an address. House Number, House Number From, and House Number To, or Building Name is required.
Building Complex
Used for search
The building complex name associated with multiple addresses. This is an area, typically residential, composed of a collection of buildings representing multiple addresses, for example, Essel Park Subdivision. A building complex encompasses a collection of Point Addresses, Subaddresses, or POIs. This field applies to Point Address and POI roles.
Parcel Join ID
JoinID used to link Parcel records to PointAddress records to minimize duplicate geocoding results. It is also used to return Parcel candidate by address search and to show the linked Parcel name in the PointAddress candidate details.
Parcel Name
Used for search
The value that represents the Parcel Identification Number (PIN), for example, 17 011100120063.
Street Join ID
JoinID to link alternate street names for the following roles: Street Address, Distance Marker, Distance Range, PointAddress, Parcel, and POI. The field is also used to link dependent street names and alternate house ranges in the Street Address role.
Prefix Direction
Used for search
The prefix direction of the address, such as East, West, North, or South.
Prefix Type
Used for search
The leading type of a street in an address, for example, the Spanish term Avenida in Avenida Central.
Street Name
Used for search
The street name of the address.
Suffix Type
Used for search
The trailing type of a street in an address, such as St, Blvd, or Ave.
Suffix Direction
Used for search
The suffix direction of the address, such as East, West, North, or South.
Full Street Name
The full street name of the address. This value is used for display purposes and is part of the output label unless it is not used. In the case where it is not used, the street components are concatenated together with spaces for the output label.
Applies to countries where street types are concatenated, such as Germany.
Primary Street Name Indicator
If the reference data is normalized and the primary table contains street name values, the Primary Street Name Indicator field can be mapped to a field in the primary table that contains a value indicating whether the record is the primary name. The Street Name role field must be mapped because it and the Primary Street Name Indicator value are used to define the Preferred Street Name value that is returned when geocoding. The supported values are P, Primary, T, True, Y, Yes, 1, A, Alternate, F, False, N, No, and 0.
Unit
Used for search
The unit value of the address, such as 201 in an address that contains Unit 201.
Unit From
Used for search
The unit starting value for the range associated with an address.
Unit To
Used for search
The unit ending value for the range associated with an address.
Unit Type
The unit type of the address, such as Apartment or Suite.
Level
Used for search
The level of the address, such as Mezzanine or 2 in Floor 2.
Level Type
Used for search
The level type of the address, such as Floor in Floor 2.
Building Unit
Used for search
The building unit of the address, such as M in building M.
Building Unit Type
Used for search
The building unit type of the address, such as building in building M.
Room
Used for search
The room value of the address, such as 102 in an address that contains Room 102. The name or number of a room that is within a unit.
Room From
Used for search
The room starting value for the range associated with an address.
Room To
Used for search
The room ending value for the range associated with an address.
Room Type
Used for search
The room type of the address, such as Room.
Wing
Used for search
The wing value of an address.
Wing Type
Used for search
The wing type of the address, such as Wing.
Side
The side of the street that the address is on, such as left (L) or right (R) in the United States. The supported values are 1, Right, R, 2, Left, L, 3, Both, B, 0, No, Not Applicable, NA, and N/A
Block Join ID
JoinID to link alternate block names.
Block
Used for search
The name of the block-level administrative division for a candidate. A block is the smallest administrative area for a country. It can be described as a subdivision of a sector or neighborhood or as a named city block. This is not commonly used.
Sector Join ID
JoinID to link to alternate sector names.
Sector
Used for search
The name of the sector-level administrative division for a candidate. A sector is a subdivision of a neighborhood or district or represents a collection of blocks. This is not commonly used.
Neighborhood Join ID
JoinID to link alternate neighborhood names.
Neighborhood
Used for search
The name of the neighborhood-level administrative division for a candidate. A neighborhood is a subsection of a city or district.
District Join ID
JoinID to link alternate district names.
District
Used for search
The name of the district-level administrative division for a candidate. It is a subdivision of a city.
City Join ID
JoinID to link alternate city names.
City
Used for search
The name of the city-level administrative division for a candidate. A city is a subdivision of a subregion or region.
Metro Area Join ID
JoinID to link alternate metro names.
Metro Area
Used for search
The name of the metropolitan area-level administrative division for a candidate. An urban area consisting of a large city and the smaller cities surrounding it can potentially intersect multiple subregions or regions. An example is Kolkata Metropolitan Area in India.
Subregion Join ID
JoinID to link alternate subregion names.
Subregion
Used for search
The name of the subregion-level administrative division for a candidate. A subregion is a subdivision of a region. To improve matching and flexibility for an address or POI when building a USA locator, use the full county name, such as San Diego County instead of San Diego, the short name of the county.
Region Join ID
JoinID to link alternate region names.
Region
Used for search
The name of the region-level administrative division for a candidate. This is a subdivision of a country or territory. Typically, the largest administrative area for a country if the Territory administrative division is not used. These values are used to apply regional geocoding logic, for example, to help create different forms of state highways that are specific to each region or state. For example, CA-38 is equal to STHY 38 in the state of California. The region abbreviation in this example is CA.
Region Abbreviation
Used for search
An abbreviated region name, such as CA for California.
Territory Join ID
JoinID to link alternate territory names.
Territory
Used for search
The name of the territory-level administrative division for a candidate. This is a subdivision of a country and it is not commonly used. The Sudeste macroregion of Brazil—which encompasses the states of Espírito Santo, Minas Gerais, Rio de Janeiro, and São Paulo—is an example.
Zone Join ID
JoinID to link alternate zone names.
Zone
Used for search
Any administrative area that doesn't fit into the above administrative hierarchy.
Postal Join ID
JoinID to link alternate postal values as well as alternate values from the AlternatePostalCityName table.
Postal
Used for search
An alphanumeric address element defining the primary postal code, for example, V7M 2B4 for a Canadian postal code and 92374 for a United States postal code.
Postal Extension Join ID
JoinID used for deduplicating geometry.
Postal Extension
Used for search
An alphanumeric address element defining the postal code extension, for example, 8110 in the United States postal code 92373-8110.
Country Join ID
JoinID to link alternate country names.
Country
Used for search
The name of the highest administrative division for a candidate. This is the country name.
Country Code
Used for search
A three-character code for a country, such as CAN for Canada. A list of supported countries and codes is available in the Supported Country Codes column referenced in the Geocode coverage map.
Language Code
Used for search
A three-character language code representing the language of the address, such as ENG for English. A list of supported three-character language codes is available in the Supported Language Codes column referenced in the Geocode coverage map.
Rank
A floating-point number value indicating the importance of a result relative to other results with the same name. For example, there are cities in France and Texas named Paris. Paris, France, has a greater population than Paris, Texas, so it has a higher rank. The smaller numbers represent higher-ranked features. Rank is used to sort results for ambiguous queries such as Lincoln, where no additional information (state) is available. Rank values are based on population or feature type. The roles that support rank are POI, Zone, Block, Sector, Neighborhood, District, City, Metro Area, Subregion, Region, Territory, and Country.
Display X
For PointAddress, Parcel, and POI locators, this value represents the actual location of the address (that is, the building or parcel centroid). It differs from the x-value, which is derived from a location along the street or the street entry for an address. For all other locators, this value is equal to the x-value. Values should be in the same coordinate system as the primary reference data’s geometry. Including this field when building the locator allows you to specify the preferred location for where the result is displayed on the map.
Display Y
For PointAddress, Parcel, and POI locators, this value represents the actual location of the address (that is, the building or parcel centroid). It differs from the y-value, which is derived from a location along the street or the street entry for an address. For all other locators, this value is equal to the y-value. Values should be in the same coordinate system as the primary reference data’s geometry. Including this field when building the locator allows you to specify the preferred location for where the result is displayed on the map.
Min X
The Min X, Max X, Min Y, and Max Y values can be combined to set the map extent for zooming to a geocode result. Values should be in the same coordinate system as the primary reference data’s geometry. The extent fields do not affect zooming to geocode results from the Street Address role.
Max X
Min Y
Max Y
Phone
The primary phone number of a place. For other searches, such as address, intersection, and postal code, the field is empty. For example, for Knott's Berry Farm, Phone is (714)220-5200.
URL
The URL of the primary website for a place. For other searches, such as address, intersection, and postal code, the field is empty. For example, for the University of Georgia, URL is http://www.uga.edu/.
Primary Name Indicator
If the reference data is normalized and the primary table does not contain name values, but the alternate name table does, the Primary Name Indicator field can be mapped to a field in the alternate name table that contains a value indicating whether the record is the primary name. The Street Name role field must be mapped because it and the Primary Name Indicator value are used to define the Preferred Street Name that is returned when geocoding. The supported values are P, Primary, T, True, Y, Yes, 1, A, Alternate, F, False, N, No, and 0.
