Privileges for geodatabases in Oracle
Privileges determine what someone is authorized to do with the data and the database. Privileges should be assigned based on the type of work the person does in the organization. Is this person involved with administration of the geodatabase? Does this person need to edit or create data? Or would this person only need to query the data?
Specific privileges must be granted to users based on what they need to do in the Oracle database. Some privileges can be granted to roles, but others must be granted directly to the user. User privileges are set at different levels.
You can use the Oracle Enterprise Manager to administer user privileges. You can also use SQL statements to grant and revoke privileges.
Privileges listed in this page apply to Oracle, Autonomous Transaction Processing, and Amazon Relational Database Service (RDS) for Oracle.
Package privileges
Execute privileges are required on the following packages:
  • dbms_lob
  • dbms_lock
  • dbms_pipe
  • dbms_utility
  • dbms_sql
  • utl_raw
You must grant the execute privilege on these packages to the public role to create or upgrade the geodatabase.
GRANT EXECUTE ON dbms_pipe TO public;
GRANT EXECUTE ON dbms_lock TO public;
GRANT EXECUTE ON dbms_lob TO public;
GRANT EXECUTE ON dbms_utility TO public;
GRANT EXECUTE ON dbms_sql TO public;
GRANT EXECUTE ON utl_raw TO public;
Tip:
The execute privilege on dbms_utility, dbms_sql, and utl_raw are granted to the public role by default in Oracle. Therefore, you only need to grant the execute privilege on these packages if you explicitly revoked them from public.
After you create or upgrade the geodatabase, you can restrict privileges on these packages by revoking them from the public role and granting them to each individual user who connects to the geodatabase, including the geodatabase administrator.
Caution:
You cannot grant the execute privilege to a role and grant the role to all the users because privileges granted through user roles are not applicable when running Oracle packages.
After granting the execute privilege to individual users, recompile the sde schema:
EXEC dbms_utility.compile_schema( 'SDE' );
Minimum privileges
In addition to the privileges stated in the previous section, the following are required for each type of user listed:
Minimum privileges in Oracle
Type of user
Database privileges
Dataset privileges
Notes
Data viewer
CREATE SESSION
SELECT on database objects
Data editor
CREATE SESSION
SELECT, INSERT, UPDATE, and DELETE on datasets owned by other users.
When you use ArcGIS to grant the SELECT, INSERT, UPDATE, and DELETE privileges on a feature class or table registered for traditional versioning, those privileges are automatically granted on the associated versioned view. These privileges are required for the user to edit using a SQL and a versioned view.
Data creator
CREATE SEQUENCE, CREATE SESSION, CREATE TABLE, CREATE TRIGGER, and CREATE VIEW
Geodatabase administrator
CREATE PROCEDURE, CREATE SEQUENCE, CREATE SESSION, CREATE TABLE, and CREATE TRIGGER
Privileges on datasets in geodatabases must be granted or revoked using ArcGIS, and must be done by the dataset owner.
Privileges required for geodatabase creation or upgrade
The following tables list the privileges that must be granted to the geodatabase administrator to create or upgrade a geodatabase in Oracle. The reason the privilege or group of privileges is needed is also listed. Some of these privileges can be revoked after creation or upgrading is completed, as noted in the Purpose field and as indicated in the minimum geodatabase administrator privileges shown in the previous table.
The first table lists the privileges required for the sde user to create a geodatabase.
The second table lists the privileges required for the sde user to upgrade the geodatabase.
Privileges are grouped by the purpose they serve during geodatabase creation and upgrading.
Oracle sde user privileges for creating a geodatabase
Privilege
Purpose
CREATE SESSION
Connect to Oracle.
CREATE TABLE
CREATE TRIGGER
Create the geodatabase repository.
CREATE SEQUENCE
Create sequences to generate IDs. This privilege can be revoked after geodatabase creation.
CREATE PROCEDURE
Create packages for maintaining the contents of geodatabase system tables.
EXECUTE ON DBMS_CRYPTO
Allows the creation of a map member function for the ST_Geometry type, which is called whenever a spatial union or intersection is performed.
CREATE INDEXTYPE
CREATE LIBRARY
CREATE OPERATOR
CREATE PUBLIC SYNONYM
CREATE TYPE
CREATE VIEW
DROP PUBLIC SYNONYM
Create the ST_Geometry data type and types used for query optimization. The CREATE VIEW privilege is needed to create system views: GDB_Items_vw and GDB_ItemRelationships_vw. These privileges can be revoked after geodatabase creation.
*The CREATE LIBRARY privilege is not required when creating a geodatabase in Autonomous Transaction Processing (ATP).
ADMINISTER DATABASE TRIGGER
Allows creation of database event triggers needed to modify the ST_GEOMETRY_COLUMNS and ST_GEOMETRY_INDEX tables if a table with an ST_Geometry column is dropped, altered, or renamed using SQL. This privilege is also required to create pl/sql triggers. This privilege can be revoked after geodatabase creation.
SELECT_CATALOG_ROLE
This privilege is only required to enable and upgrade a geodatabase in Autonomous Transaction Processing. This privilege is optional for other supported Oracle database offerings.
Oracle sde user privileges for upgrading a geodatabase
Privilege
Purpose
CREATE SESSION
Connect to Oracle.
CREATE TABLE
CREATE TRIGGER
CREATE VIEW
Upgrade the geodatabase repository. The CREATE VIEW privilege can be revoked after upgrading.
CREATE PROCEDURE
Upgrade packages for maintaining the contents of geodatabase system tables.
CREATE SEQUENCE
Upgrade sequences to generate IDs. This privilege can be revoked after upgrading.
Upgrade a map member function for the ST_Geometry type, which is called whenever a spatial union or intersection is performed.
CREATE INDEXTYPE
CREATE LIBRARY
CREATE OPERATOR
CREATE TYPE
DROP PUBLIC SYNONYM
Upgrade the ST_Geometry data type and types used for query optimization. These privileges can be revoked after upgrading.
The CREATE LIBRARY privilege is not required when upgrading a geodatabase in ATP.
ALTER ANY INDEX
CREATE ANY INDEX
CREATE ANY TRIGGER
CREATE ANY VIEW
DROP ANY INDEX
DROP ANY VIEW
SELECT ANY TABLE
Upgrade geodatabase contents.
Allows creation of database event triggers needed to modify the ST_GEOMETRY_COLUMNS and ST_GEOMETRY_INDEX tables if a table with an ST_Geometry is dropped, altered, or renamed using SQL. This privilege is also required to create pl/sql triggers. This privilege can be revoked after upgrading.
Common optional privileges
Many organizations choose to take advantage of additional Oracle features to further enhance the capabilities of their geodatabases. Several common optional privileges for the geodatabase administrator and the purposes of the privileges are listed in the following table. Privileges are grouped by the purpose they serve.
Oracle optional privileges for geodatabase administrator
Privilege
Granted to
Purpose
ALTER SESSION
PLUSTRACE
Enable SQL tracing, the SQL*Plus AUTOTRACE feature, and modifying session-specific initialization parameters for performance tuning and troubleshooting; create the PLUSTRACE role by running ORACLE_HOME/sqlplus/admin/plustrce.sql.
ALTER ANY INDEX
ANALYZE ANY
SELECT ANY DICTIONARY
Grant these privileges to the geodatabase administrator to allow this user to monitor Oracle and perform basic maintenance tasks.
This is useful for organizations in which the geodatabase administrator is not the Oracle database administrator.
CREATE DATABASE LINK
CREATE MATERIALIZED VIEW
CREATE VIEW
This set of privileges is useful for integrating the geodatabase with other nonspatial databases in the enterprise.
RESTRICTED SESSION
This privilege allows the geodatabase administrator to perform maintenance while the database is online but not accessible by end users.
UNLIMITED TABLESPACE
Granting this privilege to the geodatabase administrator for creation and upgrade ensures that there is sufficient storage space in the geodatabase administrator's tablespace in the database to complete the geodatabase creation or upgrade; this privilege can be revoked after creating or upgrading the geodatabase if you have set quotas for space management.
ALTER SYSTEM
SELECT_CATALOG_ROLE*
The sde user must have these privileges to remove connections from the geodatabase. The Create Enterprise Geodatabase geoprocessing tool grants these privileges to the sde user. You can revoke these privileges from the sde user after running this tool but, if you do, the sde user will not be able to disconnect users from the database.
Alternatively, the sde user could be added to the database administrator role to allow it to disconnect users from the database.
*The SELECT_CATALOG_ROLE privilege is required for the geodatabase administrator in Autonomous Transaction Processing.
SELECT ON DBA_ROLES
Data creators
If you want data creators to grant privileges on their datasets to database roles using the Privileges dialog box, they must be granted the SELECT privilege on DBA_ROLES to get a list of roles in the database.
INHERIT PRIVILEGES ON <user>
Or
INHERIT ANY PRIVILEGES ON <user>
sde
You must grant one of these privileges to the sde user to allow Data Pump imports of the sde user schema to be performed by another user, such as the Oracle sys or system user.
This privilege does not apply to user-schema geodatabase owners.
Other privileges
Additional privileges may be required for ArcGIS Monitor to access and monitor the geodatabase. See Register Oracle databases for more information.
