3D in ArcGIS Linear Referencing
Available with the Linear Referencing license.
ArcGIS Linear Referencing supports 3D data, including all linear referencing system (LRS) calculations where the LRS data being used is in 3D. You can visualize and edit your LRS data in a local scene in ArcGIS Pro.
Z-aware features
All feature classes that are part of the LRS data model are z-aware. To ensure that the LRS data is in 3D, the centerline features must have z-values populated. When you use these centerlines to create routes in an LRS Network, their z-values are applied to the routes. When you create events on the routes, they also receive the z-values from the route.
When you create or import centerlines, populate and update z-values before using them as parts of routes. When you append routes using the Append Routes tool, ensure that the source routes have z-values so that they are applied to the route in the network and its centerline.
Application of z-values to LRS operations
All LRS calculations in ArcGIS Linear Referencing are in 3D when the LRS data that is used has z-values populated.
The following operations and calculations are included in the software:
Calibration point generation—The Generate Calibration Points tool calculates calibration point measures in 3D, taking the 3D length of the route if z-values are populated.
Suggested measures in LRS edit activities—When making LRS edits using the Create Route, Extend Route, and Realign Route tools that include centerlines, the suggested start and end measures incorporate the 3D length of the centerlines being used for the edit.
Measure interpolation along routes—When measures are interpolated for a route in an LRS Network, the calculation of m-values along the route is based on the 3D distance between each calibration point on the route. This interpolation is also applied in the Identify Routes tool to return the measure at the location that is clicked.
If the data doesn’t have z-values, all features are assigned a z-value of 0 at each vertex. Since the z-values are the same at every vertex of each feature, any LRS operation treats this data as being in 2D and calculates accordingly.
If you want to add z-values to existing centerlines in your LRS, you can use 3D Analyst tools such as the Update Feature Z tool along with a digital elevation model (DEM) or digital terrain model (DTM). This process automatically propagates z-values to your calibration points and associated routes by invoking cartographic realignment.
After this process completes, revisit the calibration point measures because the measures do not change unless you have cartographic realignment set to update measures. After the routes are correctly calibrated, you can run the Apply Event Behaviors tool to incorporate the z-values onto the LRS events.
Edits to LRS data in 3D
You can visualize and edit LRS data in 3D using local scenes in ArcGIS Pro. When you add LRS data such as centerlines, calibration points, LRS Networks, and LRS events to a local scene with z-values populated, the Linear Referencing tab appears in your ArcGIS Pro project. You can use all of the LRS editing tools on the tab to edit the LRS data in 3D, including to create, realign, or reassign routes; to add, modify, or delete calibration points; or to split centerlines and identify routes.
If the LRS data has a vertical coordinate system configured, you must set the vertical coordinate system for the map in ArcGIS Pro to ensure that suggested measures and other functionality works correctly. The vertical coordinate system for a map can be set by opening Map Properties and configuring the z-coordinate system on the Coordinate Systems tab.
Learn more about specifying a vertical coordinate system on a map or scene
