Apply Event Behaviors (Linear Referencing Tools)
Summary
Updates the event locations for all event feature classes registered with the input network based on the route edit performed.
The events are updated according to the configured event behavior.
Learn more about configuring event behavior
Illustration
Apply Event Behaviors tool illustration
Usage
  • An LRS dataset is required to run this tool.
    Learn more about creating an LRS dataset
  • This tool will process all event behaviors for all event feature classes registered with the input network.
  • If the Input Route Features parameter value is a feature service, this tool will process edits that have not been processed earlier in the named version in use. Once the event behavior for a particular route edit is processed, it is marked as processed.
    Selection sets or definition queries used to filter the route or event records in the map are ignored to keep events in sync with route edits.
    Caution:
    This tool modifies the event records in the event feature classes. See Tools that do not create output datasets for more information and strategies to avoid unwanted data changes.
  • When conflict prevention is enabled and route edits (including create, realign, reassign, retire, extend, calibrate, and cartographic realignment) are made in a named version, run this tool before posting that version. If the route edits are made in the default version, you must run this tool before any named version can be reconciled with the default version.
  • This tool supports conflict prevention and will attempt to acquire and transfer locks.
    Learn more about conflict prevention in ArcGIS Linear Referencing
  • This tool automatically regenerates intersection features if all of the following criteria are met:
    • The edit log contains a cartographic realignment record for an LRS Network.
    • The cartographically realigned network has at least one LRS event that is a referent to an intersection associated with the network.
    • The LRS event to be updated is configured with the Honor Referent Location event behavior rule.
      Learn more about event behavior for cartographic realignment
Parameters
Label Explanation Data type
The LRS Network for which event locations will be updated. This must be a feature layer registered as a network with the LRS.
Feature Layer
Derived output
Output Event Layers
The updated event layers.
Feature Layer
Output Details File
A text file that details changes made by the tool.
Text File
Environments
Current Workspace
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
