Add calibration points
Available with the Linear Referencing license.
You can add calibration points to a route by doing one of the following:
Use the Add Calibration Point tool
on the Linear Referencing tab.Use the Create Features pane
To add calibration points to a route using the Add Calibration Point tool, complete the following steps:
Start ArcGIS Pro and add the linear referencing system (LRS) feature classes, including the calibration point feature class, to a map.
You can also open a map in which the LRS layers are present.
On the Linear Referencing tab, in the Route Editing group, click the Add Calibration Point tool
.Note:
Branch versioned networks, including any network configured with a user-generated route ID, must be edited through a feature service.
On the map, click a location on the route where you want to add a calibration point.
The Edit Calibration Point pane appears with attributes automatically populated with information from the selected route on the map.
Optionally, change the From Date and To Date values to specify when the calibration is applied to the route.
Optionally, change the measure of the calibration point in the Measure text box.
Optionally, check the Recalibrate route downstream check box to recalibrate the route downstream.
If you check this box, recalibration is applied to downstream calibration points along the route.
For example, the existing calibration measure at the location where the calibration point is being added is 9, and the next downstream calibration point at the end of the route has a measure of 15. If the measure is changed to 10 and Recalibrate route downstream check box is checked, a value of 1 is added to the downstream calibration point measure that changes to 16.
If you do not check this check box, no recalibration is applied to downstream calibration points along the route. Using the example above, changing the measure from 9 to 10 but not checking the Recalibrate route downstream check box results in the downstream calibration point maintaining a measure of 15.
Optionally, check the Retire existing calibration point check box to retire an existing calibration point at the clicked location.
This check box is only available if you click a location that has an existing calibration point.
If this check box is checked, the existing calibration point is retired and is replaced by the calibration point being added at the specified date.
Click Run.
A new calibration point is added.
If a message about acquiring locks appears, it means that conflict prevention is enabled.
Add a calibration point using the Create Features pane
To add a calibration point using the Create Features pane, complete the following steps:
You must be connected to a feature service to add calibration points using this workflow.
Zoom to the location where you want to add a calibration point.
Optionally, on the Linear Referencing tab, in the Calibration Point Settings group, click the CP Event Behavior drop-down arrow and choose one of the following to include or exclude event behaviors for manual calibration edits:
Exclude event behaviors for manual calibration edits
—Ignore event behavior in subsequent manual edits.Include event behaviors for manual calibration edits
—Include event behavior in subsequent manual edits.
On the Edit tab, in the Features group, click Create
.The Create Features pane appears.
Tip:
You can turn snapping on to improve the accuracy of the pointer.
In the Create Features pane
, click the calibration point node and choose the feature template that is based on the calibration point layer.Note:
Adding a feature layer to a map automatically generates a feature template.
Click the location on a route where you want to add the calibration point.
A new calibration point is added. The route ID, measure, and start and end dates of the calibration point are inherited from the route.
Measure value and temporality scenarios
The Add Calibration Point tool
applies downstream recalibration to a route when the Recalibrate route downstream check box is checked. The following sections show the impact with and without downstream recalibration.
With downstream recalibration
The following diagram shows the calibration points and route calibration before the edit:
The following diagram shows a new calibration point added with a user-defined measure of 5. In this example, 4 is the suggested measure based on the current calibration of the route at that location, but it is changed to 5:
If you run the Add Calibration Point tool with the Recalibrate route downstream check box checked, a new calibration point is added, downstream calibration points are updated, and the route is recalibrated.
The following diagram shows the calibration points and route calibration after the edit:
Without downstream recalibration
The following diagram shows a new calibration point added with a user-defined measure of 5. In this example, 4 is the suggested measure based on the existing route calibration, but it is changed to 5:
If you run the Edit Calibration Point tool with the Recalibrate route downstream check box not checked, the new calibration point is added and the route is recalibrated, but no downstream calibration is applied.
