Complex scenarios for route calibration
Available with the Linear Referencing license.
The following sections describe route calibration scenarios for complex routes, including loop, branch, lollipop, and alpha routes. These scenarios apply when using the calibration point editing tools on the Linear Referencing tab in ArcGIS Pro.
Calibration on a loop route
In this example, a calibration point is added in the middle of a loop route (Route X) with a new measure (2.5) instead of the existing measure (2). Because the Recalibrate route downstream option is unchecked, downstream measures do not change.
The following diagram shows the route before recalibration:
Input for calibration on a loop route
A calibration point is added using the new measure (2.5).
The following diagram shows the route after recalibration:
Output for calibration on a loop route
In this example, a calibration point is added in the middle of a loop route (Route X) with a new measure (3) instead of the existing measure (2). Because the Recalibrate route downstream option is checked, downstream measures are updated.
Example 1: Input for calibration on a loop route
A calibration point is added using the new measure (3). All downstream measures on Route X are updated.
Example 1: Output for calibration on a loop route
Calibration on a branch route
In this example, a calibration point is added on a branch route (Route X) with a new measure (2) instead of the existing measure (4.5). Because the Recalibrate route downstream option is unchecked, downstream measures do not change.
Input for calibration on a branch route
A calibration point is added using the updated measure (2). All downstream measures remain the same.
Output for calibration on a branch route
In this example, a calibration point is added on a branch route (Route X) with a new measure (9) instead of the existing measure (4.5). Because the Recalibrate route downstream option is checked, downstream measures are updated.
A calibration point is added using the new measure (9). All downstream measures are updated.
Calibration on a lollipop route
In this example, an existing calibration point (0) at the beginning of a lollipop route (Route X) is updated to a new measure (2). Because the Recalibrate route downstream option is unchecked, downstream measures do not change.
Input for calibration on a lollipop route
The calibration point is updated to the new measure (2). All downstream measures remain the same.
Output for calibration on a lollipop route
In this example, an existing calibration point (0) at the beginning of a lollipop route (Route X) is updated to a new measure (5). Because the Recalibrate route downstream option is checked, downstream measures are updated.
The calibration point is updated to the new measure (5). All downstream measures are updated.
Calibration on an alpha route
In this example, an existing calibration point (2.33) on an alpha route (Route X) is updated to a new measure (3). Because the Recalibrate route downstream option is unchecked, downstream measures do not change.
Input for calibration on an alpha route
The calibration point is updated to the new measure (3). All downstream measures remain the same.
Output for calibration on an alpha route
In this example, an existing calibration point (2.33) on an alpha route (Route X) is updated to a new measure (3.33). Because the Recalibrate route downstream option is checked, downstream measures are updated.
The calibration point is updated to the new measure (3.33). All downstream measures are updated.
