Modify calibration points
Available with the Linear Referencing license.
You can edit calibration points on a route by doing one of the following:
Use the Edit Calibration Point tool
on the Linear Referencing tab.Use the Move tool
on the Edit tab.Edit the measure of a calibration point in the calibration point layer's attribute table
The Edit Calibration Point tool
applies downstream recalibration when you modify a calibration point. ArcGIS Linear Referencing automatically calibrates the route. Use this tool to edit calibration points on a route and update their start date, end date, and measure.
Edit the measure and temporality of a calibration point
To edit the measure and temporality of a calibration point, complete the following steps:
Start ArcGIS Pro and add the linear referencing system (LRS) feature classes, including the calibration point feature class, to a map.
You can also open a map in which the LRS layers are present.
On the Linear Referencing tab, in the Route Editing group, click the Edit Calibration Point tool
.Note:
Branch versioned networks, including any network configured with a user-generated route ID, must be edited through a feature service.
Click an existing calibration point on the map.
The Edit Calibration Point pane appears with attributes for the selected calibration point populated.
Optionally, change the From Date and To Date values to specify when the calibration is applied to the route.
Optionally, change the measure of the calibration point in the Measure text box.
Optionally, check the Recalibrate route downstream check box to recalibrate the route downstream.
If you check this box, recalibration is applied to downstream calibration points along the route.
For example, if an existing calibration (or measure) at the location where you want to edit a calibration point is 5, and the next downstream calibration point at the end of the route has a measure of 10, changing a measure of 5 to 6 with the Recalibrate route downstream check box checked results in a downstream calibration point with a measure of 11.
If you do not check this check box, no recalibration is applied to downstream calibration points along the route.
For example, if an existing calibration (or measure) at the location is changed from 5 to 6, leaving the Recalibrate route downstream check box unchecked results in the downstream calibration point maintaining a measure of 10.
Click Run.
The calibration point is updated.
Move calibration points
To move a calibration point using the Move tool
Zoom to the calibration point you want to move.
Optionally, on the Linear Referencing tab, in the Calibration Point Settings group, click the CP Event Behavior drop-down arrow and choose one of the following to include or exclude event behaviors for manual calibration edits:
Exclude event behaviors for manual calibration edits
—Ignore event behavior in subsequent manual edits.Include event behaviors for manual calibration edits
—Include event behavior in subsequent manual edits.
On the Edit tab, in the Features group, click Modify
.The Modify Features pane appears.
In the Modify Features pane, expand the Alignment node, and click Move
.Tip:
If you've used the Move tool
recently, a shortcut for the tool appears on the Edit tab in the Tools group.Click the calibration point that you want to move.
The selected calibration point is highlighted on the map.
Drag the calibration point to the new location on the route.
Click anywhere on the map outside the selection to complete the move.
Tip:
You can use Undo
and Redo
on the Quick Access Toolbar to evaluate the success of the move.
The move is complete. The calibration point measure remains the same. The route measures are recalibrated between the nearest upstream and downstream calibration points of the moved calibration point.
Measure value and temporality scenarios
applies downstream recalibration to a route when the Recalibrate route downstream check box is checked. The following sections show the impact with and without downstream recalibration.
With downstream recalibration
The following diagram shows the calibration points and route calibration before the edit:
The following diagram shows an existing calibration point edited with a user-defined measure of 5:
If you run the Edit Calibration Point tool with the Recalibrate route downstream check box checked, the tool updates the calibration of downstream calibration points and recalibrates the route.
The following diagram shows the calibration points and route calibration after the edit:
Without downstream recalibration
If you run the Edit Calibration Point tool with the Recalibrate route downstream check box not checked, the tool does not change downstream calibration points.
