Delete calibration points
Available with the Linear Referencing license.
You can delete calibration points on a route by doing one of the following:
  • Use the Delete Calibration Point tool on the Linear Referencing tab.
  • Use the Delete tool on the Edit tab.
  • Delete selected rows from the calibration point layer's attribute table.
Caution:
Before deleting a calibration point, consider whether retiring the point is more appropriate. Retiring a calibration point preserves the historical integrity and calibration of the route. Deleting a calibration point results in recalibration of the route for the time span that the calibration point was active. You can retire a calibration point instead by changing its end date with the Edit Calibration Point tool .
Delete using the Delete Calibration Point tool
To delete calibration points using the Delete Calibration Point tool, complete the following steps:
  1. Start ArcGIS Pro and add the linear referencing system (LRS) feature classes, including the calibration point feature class, to a map.
    You can also open a map in which the LRS layers are present.
  2. On the Linear Referencing tab, in the Route Editing group, click the Delete Calibration Point tool .
    Branch versioned networks, including any network configured with a user-generated route ID, must be edited through a feature service.
  3. Select the calibration point you want to delete on the map.
    The Delete Calibration Point pane appears with attributes for the selected calibration point populated.
    The fields in the Delete Calibration Point pane are read-only.
  4. Click Run.
    The calibration point is deleted, and the route is recalibrated between the nearest upstream and downstream calibration points. A message appears in the Delete Calibration Point pane indicating that the point was successfully deleted.
    If a message about acquiring locks appears, it means that conflict prevention is enabled. After you select a route, the tool attempts to release the route lock if the active user acquires the route lock in a different named version and the releasable status value is Yes.
Delete using the Delete tool
To delete one or more calibration points using the Delete tool, complete the following steps:
  1. Start ArcGIS Pro and add the LRS feature classes to a map.
  2. Zoom to the calibration point that you want to delete.
  3. Optionally, on the Linear Referencing tab, in the Calibration Point Settings group, click the CP Event Behavior drop-down arrow and choose one of the following to include or exclude event behaviors for manual calibration edits:
    • Exclude event behaviors for manual calibration edits —Ignore event behavior in subsequent manual edits.
    • Include event behaviors for manual calibration edits —Include event behavior in subsequent manual edits.
  4. On the map, select the calibration point that you want to delete.
    Tip:
    Select multiple calibration points on the map to delete them all at once, then perform the remaining steps in this workflow. You can also delete calibration points in bulk by selecting them from the attribute table of the calibration point layer.
  5. On the Edit tab, in the Features group, click Delete .
The selected calibration point is deleted. Deleting a calibration point results in recalibration of the route to the nearest upstream and downstream calibration point.
Calibration point deletion scenario
The following example illustrates the three steps of deletion and recalibration using the Delete tool on the Edit tab.
First, review the calibration points and route calibration and identify a calibration point to delete. In this example, 8 is identified for deletion.
Calibration point before deletion
Then, delete the calibration point with a measure of 8.
Deleting a calibration point diagram with existing calibration point deleted
Calibration is only updated to the nearest upstream and downstream calibration points on the route.
