View LRS Network properties
Available with the Linear Referencing license.
You can view the properties of an LRS Network as either a map layer or a feature class.
To modify existing LRS Network properties, use the Modify LRS Network geoprocessing tool.
Learn more about creating and modifying an LRS Network
The following sections describe the LRS Network properties.
Name and feature class
The name and feature class properties appear at the top of the Linear Referencing tab.
Property Description
Name The name of the selected LRS Network.
Network Feature Class The feature class used to create the LRS Network.
Tolerance and resolution
You can view the following Tolerance and Resolution properties:
Measure Precision The specified number of decimal places included in the measure.
XY Tolerance The x,y tolerance set for the network feature class.
M Tolerance The m-tolerance set for the network feature class.
Z Tolerance The z-tolerance set for the network feature class.
XY Resolution The x,y resolution set for the network feature class.
M Resolution The m-resolution set for the network feature class.
Z Resolution The z-resolution set for the events feature class.
Learn more about tolerance and resolution settings for the LRS Network
Fields and network properties
You can view the following properties in the Fields and Network Properties node:
Route ID The unique identifier of the route.
Route Name The name of the route.
From Date The date the network became active.
To Date The date the network was retired.
Supports Lines Indicates whether the LRS Network is a line network.
Line ID The unique identifier of the line.
Line Name The name of the line.
Line Order The monotonic order of routes in the line.
Derived Denotes whether the network is derived from a line network.
Derived From If derived, the line network from which it's derived.
Route ID Configuration The type of route identifier configured for the selected network, either single-field or multifield. If a multifield route ID is configured, the fields that comprise the identifier are displayed.
Gap Calibration Method The gap calibration method configured for this network. Possible values are Stepping Increment, Adding Increment, or Euclidean.
Increment The increment, or measure, value configured for the gap calibration method in this network.
Update route measures in cartographic realignment Specifies whether route measures are recalibrated based on length changes in cartographic realignment. This is unavailable by default. Run the Modify Network Calibration Rules tool to enable this setting in the LRS Network.
Route dominance properties
You must configure at least one route dominance rule for the Route Dominance Properties node to appear. Each configured rule has properties that can be viewed by expanding its node.
For each configured rule, you can view the following properties in the Route Dominance Properties node:
Source Table Name The source event table or feature class used in the configured rule.
Fields The attribute field from the source table used to determine route dominance. If multiple fields are configured, they are shown.
Order Method The method to specify ordering in route dominance. Possible values are Lesser or Greater.
Order Type The ordering type to use when evaluating strings. Possible values are Numeric or Alphanumeric.
Prioritized Exceptions A comma-separated list of user-provided exceptions. Values derived from multiple fields must match the concatenated order defined in the Configure Route Dominance Rules tool's Fields parameter. For example, if SR18 is a multifield route ID that is composed of RouteType and RouteNumber attributes, the route can be listed as an exception using its concatenated name: SR18.
View network properties by map layer
You can view the properties of an LRS Network map layer from the Contents pane:
  1. Open the Contents pane in ArcGIS Pro.
  2. Right-click the network layer with the properties you want to review, and click Properties.
    The Layer Properties dialog box appears with the selected network layer name in the title bar.
    The tabs on the dialog box are specific to the selected layer type.
  3. Click the Linear Referencing tab.
    Scroll down if the tab isn't visible in the list.
    The Linear Referencing tab displays general properties for the selected layer at the top, with additional nodes below.
  4. Click the arrow for a node to expand or collapse its properties.
    If the value or field name is longer than the field, hover over the property to view its details, or resize the dialog box to view additional details.
    Tip:
    You can copy the read-only properties to the clipboard.
  5. Click OK to close the Layer Properties dialog box.
View network properties by feature class
You can view the properties of an LRS Network feature class from the Catalog pane:
  1. Open the Catalog pane in ArcGIS Pro.
  2. Expand the geodatabase connection and the feature dataset to browse to the feature class.
  3. Right-click the network feature class with the properties you want to review, and click Properties.
    The Feature Class Properties dialog box appears with the selected feature class name in the title bar.
  4. Click the Linear Referencing tab.
    The Linear Referencing tab displays general properties for the selected feature class at the top, with additional nodes below.
  5. Click the arrow for a node to expand or collapse its properties.
    Tip:
