Append network features or network objects to a network diagram
Appending network features or network objects to a network diagram allows you to add any network features and network objects that were not included when the diagram was generated. In particular, it allows you to add any new network features or network objects that didn't exist at the time the diagram was generated.
You can append network features or network objects to a network diagram using the Append command in the Manage group on the Network Diagram tab, or in the Diagram group on the Utility Network or Trace Network tabs on the ribbon. The Append To Diagram geoprocessing tool can also be used.
Appending network features or network objects to subnetwork system diagrams is not allowed because these diagrams are exclusively maintained by the Update Subnetwork tool.
Requirements
The following prerequisites must be met before appending network features or network objects to a diagram:
  • The network topology must be enabled.
  • Since this operation is transactional, edits must be saved before it is run.
  • This operation applies to a network diagram layer that is from either a utility network or trace network in a file or mobile geodatabase, or a network diagram service. When working with a utility network or trace network in an enterprise geodatabase, the input network diagram layer must be from a service.
  • The related diagram template must enable the diagram to be extended.
  • There are network features or network objects selected in the network map you specified for the appending process.
  • The network features or network objects selected in the specified network map and the network diagram must share the same trace network or the same utility network branch version.
  • There are no dirty areas on the network features initially used to generate the diagram, whether they are visible or aggregated.
  • There are no dirty areas on the container features related to the network objects initially used to generate the diagram, whether they are visible or aggregated.
  • There are no dirty areas on the network features appended to the diagram.
  • There are no dirty areas on the container features related to the network objects appended to the diagram.
  • The All Layers diagram mode must be turned on for the diagram layer to which the operation applies so all layers are present in the Contents pane whether they contain diagram features or not. If it is turned off, on the Network Diagram tab, in the Manage group, click All Layers .
Caution:
With this version, if you have an edit session open, you must save edits before appending network features or network objects to your diagram. This allows the network and diagram edits to be consistent. Without saving, none of the unsaved edits will be reflected in this diagram.
Append network elements to a network diagram
There are two ways to append network features or network objects to an existing diagram: either from the Utility Network or Trace Network contextual tab or from the Network Diagram home tab.
Before you begin one of the workflows below, complete the following steps to open the desired diagram and select the network elements you want to append to it:
  1. If the diagram you want to modify is not already open, run the Find Diagrams function on the Network Diagram tab. Alternatively, open the diagram on the Utility Network or Trace Network tab in the ribbon.
  2. Open the map view that references the network.
  3. Select the network features and network objects you want to append to the diagram.
Append network features or network objects currently selected in the active map to a network diagram
To append network features or network objects currently selected in the active map to a network diagram, complete the following steps:
  1. Activate the map that references the network features or network objects you selected and want to append to your diagram.
  2. Click the network layer in the Contents pane.
  3. On the Utility Network or Trace Network tab on the ribbon, click the drop-down arrow under the Append button in the Diagram group, and click the diagram to which you want the selected network features or network objects to be appended.
    The diagrams proposed in the drop-down list are those referenced in any open map and currently displayed with the All Layers mode turned on. If none of the open diagrams fit these conditions, the drop-down list displays No valid maps.
Append network features or network objects currently selected in a map to the active network diagram
To append network features or network objects currently selected in a map to the active network diagram:
  1. Activate the diagram map referencing the network diagram to which you want to append network features or network objects.
  2. Click the network diagram layer corresponding to the diagram to which you want to append network features or network objects.
  3. On the Network Diagram tab, click the drop-down arrow under the Append button in the Modify group. Click the map containing the set of network features or network objects you want to append to the active diagram.
    The maps proposed in the drop-down list are those that are open and reference the same network as the one related to the active diagram.
Network diagram appending process
In both workflows, when the tool runs, the append process creates diagram features corresponding to network features and network objects selected on the map and runs a complete update of the diagram content with regard to the network features or network objects that were initially used to generate the diagram. It also reruns any rules that may be configured on the diagram template. The positions of the diagram features that existed before the append operation are preserved; any new features added or appended to the diagram display according to the following rules:
  • Any diagram point junction representing a network point feature displays at the point feature's geographic position.
  • Any diagram point junction representing a network polygon feature is placed at the center of the feature boundary envelope.
  • Any diagram point junction representing a network junction object is placed at best inside the diagram polygon container representing its spatial container with some or all other contents.
  • Any diagram polygon container representing a container point feature displays as a rectangle around its contents where the center is placed at the point feature geographic position.
  • Any diagram polygon container representing a container polygon feature displays as a rectangle around its contents where the center is placed at the center of the feature boundary envelope.
  • Any diagram polygon container representing a container junction object displays as a rectangle around its contents and is placed at best inside its own diagram polygon container.
  • Any diagram edge representing a network edge object displays as a straight line between its from and to diagram junction.
  • Any diagram edge representing a network line feature displays with the line feature geometry when the Keep Edge Vertices property is set to Yes on its related diagram template; otherwise, it displays as a straight line between its from and to diagram junction.
Caution:
Starting with ArcGIS Pro 3.5 | ArcGIS Enterprise 11.5, you can create diagrams from input trace locations. Such a diagram keeps track of the initial input trace locations and allows the diagram update to process from those saved trace locations. This remains true as long as no user forces any diagram building operation like in this workflow.
When running the Append To Diagram function on a diagram created from trace locations, the initial network features or network objects considered at the beginning of the process are those specified as starting points at diagram creation. At the end of the Append To Diagram operation, these network features or network objects and those currently selected on the network map are merged and become the diagram's new initial input while the previous input trace locations are deleted from the diagram properties.
