Build parcels from lines
Building parcels creates missing parcel features. Parcels can be built from lines or polygons.
When parcels are built from lines, parcel polygons and parcel points are created. Additionally, the following data is updated:
Parcel record polygons are updated to match the cumulative geometry of all the parcels associated with them.
If there are only connection lines, the record polygons will match the extent of the connection lines.
The Parcel Count field in the Records feature class is updated with the number of parcels associated with each record.
Building parcels from lines fixes the following default topology errors:
Lines—Endpoint Must Be Covered By—Points
Lines—Must Be Covered By Boundary Of—Polygons topology errors
Only current parcels are built. Historic parcels are not built.
The build process uses the following default values:
Record polygons will be not be created or updated for records that are associated to more than 2,000 parcels.
The maximum number of parcels that can be built using the Build Active
and Build Extent
commands is 1,000.
To change these numbers, right-click the parcel fabric in the Catalog pane and click Properties. Expand Parcel Fabric under General and provide new values for Maximum Number Of Parcels For Build and Maximum Number Of Parcels For Record Polygon.
Create or add parcel lines
Parcels can be built from lines stored in the parcel type lines feature class. The parcel type lines feature class is a COGO-enabled lines feature class and stores COGO dimensions in COGO fields such as Direction and Distance.
Parcel lines can be created in or added to a parcel type in the following ways:
Create lines using editing tools such as the Traverse tool.
Copy lines from existing lines in the parcel fabric, CAD files, or other feature classes.
When creating parcel lines, an active record must be set for the map. New lines will be associated with the active record.
Create parcel seeds
When building parcels from lines, parcel seeds are used. A parcel seed is the initial state, or seed state, of a parcel. A parcel seed indicates to the build process that a parcel can be built from the lines enclosing the seed.
Learn more about creating parcel seeds
Build parcels in the active record
Click Build Active
in the Construct group on the Parcel Record Workflows tab to build parcels associated with the active record.
When there are parcel lines or connection lines in the active record, the build in the active process will work as follows:
All seeds associated with the active record will be built into parcels, even if the seeds lie outside the current map extent.
If there are only connection lines in the active record, the record polygon will be created to match the extent of the connection lines.
Build strata parcels
Strata parcels can be built from multiple, overlapping closed loops of lines and seeds. Strata parcels represent floor levels and are also known as condominiums, units, flats, apartments, and basements. Before creating strata parcels, ensure the parcel type supports the storage of strata parcels.
For a closed loop of lines to be built as a floor level parcel, their FloorOrder fields must be populated with an integer value that represents the floor level, for example, 0, 1, 2. Negative values can be used to represent floor levels that are below ground, for example, -1, -2. There must also be a corresponding seed created for each overlapping loop of lines.
Once the strata parcel is built, the FloorOrder field of the parcel polygon is populated with the same floor level as the lines used to build the parcel.
Learn more about creating strata parcels
Build parcels in the map extent
Click the Build Active drop-down arrow and click Build Extent
to build parcels from lines enclosing seeds in the map extent. If a loop of lines does not enclose a seed, the parcel will not be built.
Building the map extent works as follows:
Only lines and seeds in the map extent that are associated with the same parcel record will be built into parcels.
If lines enclosing a seed belong to different parcel records, the parcel will not be built.
The command will associate newly built parcel polygons and points with the parcel record that the seed is associated with.
The Build Extent command is limited to the number of parcels specified for Maximum Number Of Parcels For Build in the parcel fabric properties. To build a larger number of parcels, run the Build Parcel Fabric geoprocessing tool.
The Build Extent command turns off the Show Only Active command if it is on.
If a seed is not visible in the map extent, the parcel is not built.
When building parcels from lines and seeds, parcel polygons and parcel points are created. The built parcel features are associated with the same parcel record as the parcel seed.
