Add a named trace configuration
Available with Standard or Advanced license.
Named trace configurations are created using the Add Trace Configuration tool. These allow you to create complex traces that can be reused in ArcGIS Pro and shared across an organization through web maps and consumed by web and field applications.
Requirements
The following requirements apply:
The input trace network must be version 2 or later.
When working with an enterprise geodatabase, the input trace network must be from a trace network service.
The connected portal account is set as the creator of the trace configuration.
Operating system authentication is used to store the creator of a trace configuration when working with a single-user deployment of the trace network.
- The creator of a named trace configuration controls access to view and make modifications to the configuration in an enterprise geodatabase.
Create a named trace configuration
Follow these steps to create a named trace configuration in the trace network:
On the Analysis tab, in the Geoprocessing group, click Tools
to open the Geoprocessing pane.In the Geoprocessing pane, search for and choose Add Trace Configuration.
The tool is in the Trace Configuration toolset of the Trace Network toolbox.
For Input Trace Network, specify a trace network.
For Trace Configuration Name, specify a name for the named trace configuration.
For Description, optionally, provide a description for the named trace configuration.
For Tags, optionally, provide user tags to identify the named trace configuration.
Apply additional configuration parameters as needed.
Reference the Trace tool for a full list of tool parameters.
Click Run.
A new named trace configuration is added to Input Trace Network.
Named trace configurations created in a trace network can be consumed in ArcGIS Pro with the Trace geoprocessing tool or by using the Named Configurations tab in the Trace pane. When working in an enterprise deployment, these can also be shared through a web map and consumed by web and field apps.
