Configure a preset template
After you create a preset template, configure the tool palette, specify the default attributes applied to new features, and move the insertion anchors to locations that help rotate and snap the features into place. These settings are available in the Template Properties dialog box.
Preset template property settings appear on the following side tabs:
Tab
General
The template name and optional metadata for documenting, organizing, and searching.
Tools
Settings for tools that appear on the tool palette.
Preset templates use point construction tools to add, rotate, and snap the features into place using the active snap settings.
Features
Features in the template and the attribute values applied to them.
  • Features are identified by the display field layer property setting. If the field is null, the OBJECTID field value is shown.
  • To remove a feature from the template, hover and click the Remove button . Removing a feature doesn't update the location of the insertion anchor.
Preview
A preview of the features and locations of the insertion anchors.
Select a template
Select a template in the Manage Templates pane and click Properties .
  1. On the ribbon, click the Edit tab. In the Manage Edits group, click Manage Templates Manage Templates
    Alternatively, click Manage Templates in the Create Features pane.
    The Manage Templates pane appears.
  2. In the layer view, expand Map and click the layer for which the template is defined.
    The associated templates appear in the template view.
  3. In the template view, click the template.
  4. Click Properties on the template view toolbar,.
    Alternatively, right-click the template and click Properties .
    Tip:
    To change the properties of an active template in the Create Features pane, right-click the template and click Properties . This command is also available in the Active Template view on the Options menu .
Configure the tool palette
On the Tools side tab, show or hide the tools that appear on the tool palette and choose which tool automatically runs when the template is activated.
  1. Click the Tools side tab.
  2. Hover over the Click to set as default tool buttons and enable one tool to run automatically when the template is active.
  3. Hover over the Toggle tool visibility check boxes and check the tools you want to appear on the tool palette.
Specify attribute values
On the Features side tab, click the feature in the Features view and type the attribute values in the Attributes view. Field values are saved with the template.
You can type the values or right-click the field and set it to the geodatabase default value or restore it to the value last saved with the template, or get a unique value contained in the source attribute table.
Caution:
In this release of ArcGIS Pro, preset templates do not support attribute fields for raster data, attachments, or binary large objects (BLOBs).
  1. Click the Features tab.
    The feature in the template appear in the Features view, and attribute fields for the selected feature appear in the Attributes view.
  2. Click the feature in the Features view for the attributes you are changing.
  3. In the Attributes view, click a field and type a value.
    Click the drop-down arrow for fields constrained by coded domains, or click the Choose Symbol Class button for fields that symbolize the layer.
    Tip:
    Hover over the field name to view the data type, default geodatabase value, and other field properties.
    Alternatively, use the following methods to change a value:
    Right-click the field and click Set To '<Null>' .
    Set the value to Null if the field accepts null values.
    Right-click the field and click Revert .
    Restore the field value to the value defined in the template property settings.
    Click the Options menu and click Revert .
    Restore all field values to the values defined in the template property settings.
    Right-click the field and click Get Unique Values.
    This command is not available for field values constrained to an attribute domain.
    Choose a value currently stored in this field.
    Right-click a field with an existing value and click Copy . Right-click the field you are overriding and click Paste .
    These commands are not available for field values constrained to an attribute domain.
    Copy and paste a value from an existing field.
  4. Click OK.
    Your settings are saved and the dialog box closes.
Field color codes
The appearance of a field border or fill color indicates how the attribute is functioning, or its editability, validity or other status listed in the following table:
Field color
Orange shading
This is the subtype field.
Purple shading
This symbolizes the layer.
Yellow shading
The Highlight property is enabled in the Fields view.
Gray border
The field is read-only and can't be edited.
Green border
The field is not using the geodatabase default value.
Blue border
The field is using the geodatabase default value.
Yellow border
The field value is an invalid entry for the optional contingent values assigned to the field.
Red border
The field value is an invalid entry for one of the possible reasons:
Attribute field color codes
Set the insertion anchors
On the Preview tab, move the primary and secondary insertion anchor to locations that help the anticipated workflow to effectively add the features to a map, rotate them, and snap them into place.
  1. Click the Preview tab.
    The pointer defaults to the Pan tool .
  2. In the viewer window, click Zoom to Extents .
    The features the template creates appear in the window with an insertion anchor. The anchor defines the insertion point for the features when they are added to a map and snaps to other features based on the active snap settings.
  3. To move the insertion anchor, hover over the anchor and drag it when the pointer changes to the Move cursor .
    The anchor snaps to feature geometry in the viewer using the active snap settings.
  4. To show and set the secondary anchor, hover and snap the pointer to the target location and press the S key.
    The secondary anchor is used with the Point with rotation construction tool to snap the rotation angle to other features. The primary anchor serves as the center of rotation.
    A temporary dashed line and arrow points to the new position of the secondary anchor.
    Preview tab
  5. To reset both anchors, click the Reset button on the preview toolbar.
    This command restores the primary anchor to the default position and clears the secondary anchor.
  6. Click OK.
