Update COGO attributes
The Update COGO tool updates the direction and distance attributes of a COGO-enabled line feature to match the geometry of a selected feature. This tool is available In the Modify Features pane.
When you use this tool, consider the following
  • You can specify a value tolerance to preserve existing values that do not exceed the tolerance.
  • If ground to grid corrections are turned on, the calculated values are rotated and scaled by the current correction settings.
Tip:
When using the Attributes pane, the unit drop-down selector that appears with some field types, such as COGO Direction and Distance fields, lists the unit options defined for the project. Change the unit format to convert the current value into the unit required for the COGO-enabled line feature class.
To update COGO attributes, complete the following steps:
  1. On the ribbon, click the Edit tab. In the Corrections group, click Ground To Grid and confirm your settings.
  2. On the Edit tab, in the Features group, click Modify .
  3. In the Modify Features pane, click Update COGO .
    To find the tool, expand COGO, or type Update COGO in the Search text box.
  4. In the tool pane, click Select one or more lines and select a COGO-enabled line feature.
    To change the selection method, click the selection drop-down arrow.
    To remove features from the selection in the pane selection view, right-click a feature and click Unselect , or click Only Select This to keep the feature and remove all others from the selection.
  5. To update distance attributes, check Distances and click one of the following options until it appears filled:
    Update all values
    Update all distance attributes.
    Update by a value difference tolerance
    Update distance attributes only when the new calculated value exceeds the specified distance.
    • Specify the distance in the Distance difference parameter box.
    • Specify a distance of zero (0) to update only the attributes that are currently set to Null.
  6. To update direction attributes, check Directions and click one of the following options until it appears filled:
    Update all values
    Update all direction attributes.
    Update distance attributes only when the new calculated value exceeds the specified direction and lateral offset.
    • Specify the direction and lateral offset in the Direction difference and Lateral offset parameter boxes.
    • Specify a direction and offset of zero (0) to update only the attributes that are currently set to Null.
  7. Click Update.
