Extrude features to 3D symbology
Extrusion is the process of stretching a flat, 2D shape vertically to create a 3D object in a scene. For example, you can extrude building polygons by a height value to create three-dimensional building shapes. Only points, lines, and polygons support extrusion.
Layer extrusion
When you extrude a layer in the 2D Layers category in the Contents pane, it is moved to the 3D Layers category. You can only extrude a single layer at a time. If more than one layer is selected in the Contents pane, extrusion choices are unavailable. Extrusion is only available in scenes.
Point extrusion
Point and multipoint features become hollow vertical columns when extruded, regardless of the point symbol applied. Extrusion is a good way to highlight locations in 3D. You can extrude points based on an attribute to create columns of different lengths to visually represent variability in the data.
Each point feature has a singular height value, so the Minimum Height and Maximum Height extrusion types are unavailable for point features.
A comparison of point features on the ground and point features extruded to lines is shown below:
Point features on the ground Point features extruded to lines
Line extrusion
Extruded line features appear as walls. This can be an effective way to represent and highlight boundaries in 3D. You can extrude based on an attribute value to show walls of varying heights, which can be an effective way to represent the magnitude of flow or other movement.
Extruded lines will appear as 1-pixel-wide walls, regardless of the width of the stroke symbol layer in the line's symbol.
Learn more about unsupported symbol drawing
A comparison of a line feature on the ground and a line feature extruded to a wall is shown below:
Line on the ground Line extruded to a wall
Polygon extrusion
Polygon features are extruded vertically to create blocks. This is a convenient way to represent building footprints as 3D buildings. You can also extrude polygons by an attribute to create 3D prism maps, such as property prices, county population, or census block income.
If there are outlines on the polygon symbols prior to extrusion, the extruded blocks will draw with a 1-pixel-wide outline on all edges in the color defined by the symbol, regardless of the outline width or other symbol properties set on the outline stroke layer or layers.
A comparison of building footprints on the ground and building footprints extruded to three-dimensional shapes is shown below:
Building footprints on the ground Building footprints extruded
Extrude features
Follow these steps to extrude features:
  1. Select the layer you want to extrude in the Contents pane.
  2. On the layer's contextual tab (for example, the Feature Layer tab), in the Extrusion group, click the Type drop-down arrow. Choose a feature extrusion type.
    None Extrusion None
    Features are not extruded. This is the default.
    Min Height Min Height (line and polygon extrusion only)
    Add extrusion to each feature's minimum height. A z-value is calculated by adding the extrusion height to the minimum z-value of each feature. They are extruded to a flat top at that value.
    Max Height Max Height (line and polygon extrusion only)
    Add extrusion to each feature's maximum height. A z-value is calculated by adding the extrusion height to the maximum z-value of each feature. They are extruded to a flat top at that value.
    Base Height Base Height
    Add extrusion to each vertex of each feature's base height. A z-value is calculated for each vertex of the feature's base and each feature is extruded to those z-values. In the case of polygon features, top and base faces are created to connect to the extruded walls to construct a closed shape.
    Absolute Height Absolute Height
    Each feature is extruded to the specified z-value from a field or expression as a flat top, regardless of the z-values of each feature.
    If no field or expression is specified for extrusion, the surface elevation of the lowest or highest vertex is used to determine the elevation of the polyline or polygon. Points do not draw until a field is chosen.
  3. Optionally, click the Field drop-down list to choose a field from the layer's attribute table to use as the extruded height value.
  4. Optionally, click the Unit drop-down list to choose the measure of units for the feature's extrusion.
    If the layer has a vertical coordinate system defined, the default extrusion unit is the vertical unit of the data source. Otherwise, the default extrusion unit is meters.
    Tip:
    To see the vertical unit defined for the data source, right-click the layer in the Contents pane, and click Properties. On the Layer Properties dialog box, click the Source tab and expand the Data Source heading.
  5. Optionally, click the Extrusion Expression button to create a custom expression in VBScript or Arcade to calculate the extrusion values.
    The extrusion text box is available if you choose any extrusion method except None. You can also choose to apply any operators to the attribute value. For example, if you have the height of each building floor as your attribute field, and you know how many floors the building has, you can add a multiplier to calculate building height. For more information, see Set custom expressions for symbology.
    Caution:
    With Windows 11, version 24H2, VBScript becomes a feature on demand and requires the VBScript capability.
    Do one of the following:
    • Convert the expression type to Python or Arcade.
    • Enable the VBScript optional feature in the Windows system settings.
Extrusion is a display property of the layer, so the individual symbol or symbols used in the layer will not reflect extrusion in the symbol properties preview window.
