Explore simulation results with pop-ups
Click any cell of simulated water to open a pop-up window that lists the details of that cell. These details include the following:
  • Water depth in meters (m)
  • Water speed in meters per second (m/s)
  • Water flow rate in cubic meters per second (m³/s)
  • Water flow direction in degrees (°)
Pop-ups are not returned for water sources, drainage, or barriers individually but, the pop-up can be further configured to include statistical information about such elements. To configure a pop-up for a simulation layer, right-click the layer in the Contents pane and click Configure Pop-ups to open the Configure Pop-ups pane.
Arcade expressions can be used, for example, to convert the default details into a different unit of measure.
Alternatively, the pop-up can be disabled so that no pop-up is seen when the simulated water cell is clicked. Right-click the simulation layer in the Contents pane and click Disable Pop-ups .
Add element values to a pop-up Fields element
The Fields element of a simulation pop-up can be configured to include additional information about each added simulation element. Each element type can only include values from a predetermined list of available values. The order these elements appear in the pop-up matches the order seen in the Contents pane and cannot be altered.
The list of values available for each simulation element are the following:
Simulation element
Available values
Water Source Areas
  • Current Flow Rate
  • Area
Water Source Points
  • Current Flow Rate
Channels
  • Diameter
  • Length
  • Slope
Water Sink Areas
  • Current Flow Rate
  • Current Amount
  • Maximum Intake
  • Area
Barriers
  • Height
  • Width
  • Length
To add a simulation element value to a Fields element in a pop-up, perform the following steps:
  1. Right-click the simulation layer in the Contents pane and click Configure Pop-ups .
    The Configure Pop-ups pane appears.
  2. In the Configure Pop-ups pane, double-click the Fields element or click the Edit pop-up element button to edit the properties of the Fields element.
  3. Expand the simulation element type header, for example Barriers, and check each element to be included in the pop-up.
    A list of available values appears at the end of each heading list.
  4. Check each value to be included.
    If no values are checked, the element itself is unchecked when the changes are saved.
  5. Click Back to commit your changes.
