Orient line labels to graticules or direction
Using the Maplex Label Engine to set line label orientation allows you to place labels so they align with the lines of latitude of a map's projection. It also allows you to place labels so they follow the digitized direction of features. This is useful for placing one-way arrow symbols for streets.
You can control how line labels are oriented on the map. If you choose a horizontal placement position and your map is in projected space, you can choose to align the labels with the latitude graticules. There are four graticule alignment types to choose from:
  • Straight
  • Straight (no flip)
  • Curved
  • Curved (no flip)
The Straight and Curved options place the label in alignment with the graticule and orient it to the page. The Straight (no flip) and Curved (no flip) options allow the label to be drawn upside down to align with the graticule.
Tip:
If the data is not in projected coordinates, the labels will not align. They will remain in their original position.
Learn more about map projections
The following image shows the line label oriented to the graticules.
Line label oriented to the graticules
  1. Ensure that the Maplex Label Engine is enabled.
  2. Ensure that List By Labeling is the active method of displaying the Contents pane. Click the List By Labeling tab .
  3. Choose a label class in the Contents pane, and click the Labeling tab.
  4. On the Labeling tab, in the Label Placement group, click Label Placement Properties .
  5. In the Labeling pane, click Position, and click the Position tab .
  6. Expand Placement.
  7. Choose the Regular placement style and the Centered horizontal or Offset horizontal placement position.
  8. Expand Orientation.
  9. Choose the graticule alignment type: Straight, Straight (no flip), Curved, or Curved (no flip).
Align labels with line direction
By default, labels are placed in top-down and left-to-right readable positions. Occasionally, you may need to place labels in the same direction as the line features. In these cases, you can align labels with the direction of the lines. This is useful for placing flow symbols on lines, such as the one-way arrows on a street map or the water flow direction on a hydrography map.
With curved placement styles, label callouts will not be oriented to the direction of the line and label text, and the callout will be page-aligned. For labels whose callouts also align to the label, use a straight placement style.
The following image shows the arrow label oriented to the line direction. This is used for showing the flow direction of the river.
The label is aligned to the direction of the line to show flow direction.
  7. Choose the Regular placement or River placement style.
  8. Optionally, choose a different label placement position.
  9. Expand Orientation.
  10. Check the Align label to direction of line check box.
    This can be useful if flow arrow symbols are represented by glyphs in fonts and need to be placed in the direction of the line. Note that this option can result in labels being placed upside down.
