Event editing using feature edits
Available with Location Referencing license.
You can edit an event feature in a feature service event layer using the Edit Vertices tool .
Using this method, you can edit an existing event shape. The event’s route ID, route name, and measures are updated accordingly. The event’s dates do not change.
When an event is moved from one route to another route, the event's time slice is based on the route's start and end dates.
Learn more about editing features using standard editing tools in ArcGIS Pro
If a message regarding acquiring locks or reconciling appears, conflict prevention is enabled.
After a route is selected, the tool will attempt to release the route lock if the route lock is acquired by the active user in a different version and its releasable status value is Yes.
After editing an event’s vertices, you can retire the existing event and create a new event with a start date (From Date) as of the specified retire date including the edited vertices. You can also merge any coincident line events. For more information, refer to the event editing options under Location Referencing options in ArcGIS Pro.
Location errors
The location error attributes provide information about the status of each event feature. When an event feature is edited correctly, the No Error value is displayed in the location error field of the event. If the status is anything other than No Error, inspect the modified event feature and its attributes for issues and resolve them.
You can also review a complete list of location errors.
Any of the following statuses indicate a problem that should be resolved:
Location error
Different From Route And To Route Line IDs
The starting route and the ending route have different line IDs. This is applicable to events associated with line networks.
Invalid Location Route ID
The route location's route ID is invalid (NULL, empty, or invalid value).
Invalid Location Measure
At least one of the route location's measure values is invalid.
Invalid Route ID
Reversed Line Order
The starting route does not have a lower line order than the ending route. This is applicable to line networks.
Route Not Found
The route does not exist. This may be due to the route not existing in the network or the route and event having different time ranges that do not overlap.
Scenarios for editing line events using feature edits
The scenarios below detail the results of editing event features using the Edit Vertices tool .
Edit a line event
The following diagram shows the route and its associated event. Route1 has measures from 0 to 20, and Event1 has measures from 0 to 10.
Before editing Event1 on Route1
The following table details the route attributes:
Route ID
From Date
To Date
Route1
1/1/2000
<Null>
The following table details the event before editing:
Route ID
From Date
To Date
From Measure
To Measure
Location Error
MAOP Design
Route1
1/1/2005
<Null>
No Error
800
To edit the event so that it runs from 0 to 20, where the intersection with Route2 is located, drag the last vertex of the event to the intersection using the Edit Vertices tool . The first vertex is used as the starting measure, and the last vertex is used as the ending measure.
Event1 after selection
The following diagram shows the event after editing:
After editing line event on Route1
The following table details the event after editing:
Route ID
From Date
To Date
From Measure
To Measure
Location Error
MAOP Design
Route1
1/1/2005
<Null>
No Error
800
Edit a line event resulting in a location error
The following diagram shows the route and its associated event. Route1 has measures from 0 to 20, and Event1 has measures from 0 to 15.
Nonspanning event on Route1 before being moved to Route2
Route ID
From Date
To Date
Route1
1/1/2000
<Null>
The following table details the event before editing. Event1 on Route1 has measures from 0 to 15.
Event ID
Route ID
From Date
To Date
From Measure
To Measure
Location Error
MAOP Design
Event1
Route1
1/1/2000
<Null>
No Error
800
During the edit, Event1 is dragged beyond the intersection and beyond the end of Route1. In this case, the event's shape remains intact and a location error occurs.
Event1 after dragging the last vertex to a new location
The following table details Event1. Since the event's end measure cannot be located, a location error occurs.
Event ID
Route ID
From Date
To Date
From Measure
To Measure
Location Error
MAOP Design
Event1
Route1
1/1/2000
<Null>
<Null>
800
The following diagram shows the route after relocating the end vertex of the line event (Event1) on Route1:
Nonspanning event on Route1 after being moved to Route2
Scenarios for editing spanning events using feature edits
The scenarios below detail the results of editing a spanning line event using the Edit Vertices tool .
Edit a spanning event
The following diagram shows the routes and their associated event. Route1 and Route2 are on LineA.
Before editing a line event that spans routes
Route ID
From Date
To Date
Route1
1/1/2000
<Null>
Route2
1/1/2000
<Null>
Event ID
From Route ID
To Route ID
From Date
To Date
From Measure
To Measure
Location Error
MAOP Design
Event1
Route1
Route2
1/1/2000
<Null>
20
No Error
800
In this case, the event is edited so that the start vertex of the event is snapped to measure 0 on Route1, and the end vertex of the event is snapped to end measure 25 of Route2.
Event1 after dragging the first and last vertex to new locations
Event
From Route ID
To Route ID
From Date
To Date
From Measure
To Measure
Location Error
MAOP Design
Event1
Route1
Route2
1/1/2000
<Null>
No Error
800
The following diagram shows the route and its associated event after the edit:
After editing a spanning line event resulting in no error
Edit a spanning event resulting in a location error
The following diagram shows the routes and their associated event. Route1 and Route2 are on LineA, and RouteX1 is on LineB. Event1 spans from measure 5 on Route1 to measure 20 on Route2.
The following table details the route attributes. RouteX1 is located on LineB.
Route ID
From Date
To Date
Route1
1/1/2000
<Null>
Route2
1/1/2000
<Null>
RouteX1
1/1/2000
<Null>
Event ID
From Route ID
To Route ID
From Date
To Date
From Measure
To Measure
Location Error
MAOP Design
Event1
Route1
Route2
1/1/2000
<Null>
20
No Error
800
In the following diagram, the event is edited so that the last vertex of the event is snapped to measure 35 of RouteX1, which is on a different line (LineB).
The following table details Event1 after editing. Because the event's ending measure cannot be located on the same line, the event is drawn only up to the end of Route2 on LineA and a location error describing the issue is provided.
Event
From Route ID
To Route ID
From Date
To Date
From Measure
To Measure
Location Error
MAOP Design
Event1
Route1
RouteX1
1/1/2000
<Null>
35
Different From-Route and To-Route Line IDs
800
The following diagram shows Event1 after the error. The event is generated without the LineB segment.
After editing a line event on a spanning route resulting in an error
Referent offset when using feature edits
The Pipeline Referencing events data model supports the configuration of referent event fields and their enablement using the Enable Referent Fields tool. Once referent fields are configured and enabled in a layer, referent locations are populated and persisted in that layer when events are added or edited.
When a line event is edited using feature edits in a referent-enabled layer, the parent LRS Network is used as the FromRefMethod and ToRefMethod values by default, and the route is used as the FromRefLocation and ToRefLocation values. The start and end measures of the line event are used as the FromRefOffset and ToRefOffset values.
If either measure of a line event is updated, the corresponding offset value updates to reflect the new measure.
The example below demonstrates the impact of editing events that have user-configured referent values enabled in the event layer.
Before editing with referents
The following diagram shows the route and its associated events:
Before editing events with specified measures that override referents
The following table provides details about the event referent fields before the edit:
FromRefMethod
FromRefLocation
FromRefOffset
ToRefMethod
ToRefLocation
To Ref Offset
PointEventLayer1
Point1
PointEventLayer1
Point1
15
The following table provides details about the default event fields before the edit:
Event ID
Route ID
From Date
To Date
From Measure
To Measure
Event1
Route1
1/1/2000
<Null>
10
20
After editing with referents
After editing events with referents honored
When applying feature edits to an event record that has user-configured referent fields, the FromRefMethod and ToRefMethod values revert to the parent LRS Network, and the FromRefLocation and ToRefLocation values revert to the route.
The following table provides details about the event referent fields after event editing:
FromRefMethod
FromRefLocation
FromRefOffset
ToRefMethod
ToRefLocation
To Ref Offset
PipeSeriesNetwork
Route1
PipeSeriesNetwork
Route1
15
The following table provides details about the default event fields after the edit:
Event ID
Route ID
From Date
To Date
From Measure
To Measure
Event1
Route1
1/1/2000
<Null>
15
