Use authentication connections in ArcGIS Pro
The Authentication page in ArcGIS Pro supports adding OAuth 2.0-based authentication connections that are used to securely access and work with resources that require authentication. These connections establish a relationship between external providers and ArcGIS Pro, allowing the application to access and manage resources on your behalf.
You can add Microsoft OneDrive, Microsoft Entra ID, Google, Custom, and Client Credentials connections. For connection types that require user sign-in, you are redirected to the provider's login page to provide your credentials. Once signed in, you can use the authentication connection in various parts of the application, such as cloud storage connections, Open Geospatial Consortium (OGC) service connections, and SpatioTemporal Asset Catalog (STAC) connections.
To access the Authentication page, complete the following steps:
  1. Open the ArcGIS Pro settings page in one of the following ways:
    • From an open project, click the Project tab on the ribbon.
    • From the start page, click the Settings tab .
  2. In the list of side tabs, click Authentication.
Connect to Microsoft OneDrive
If your organization uses Microsoft OneDrive and Microsoft SharePoint to store files, an administrator can enable protected access for Microsoft OneDrive files through application settings. When protected access is enabled, sign in to your Microsoft work or school account to help maintain data integrity of protected files that you work with in ArcGIS Pro.
Learn more about connecting to Microsoft OneDrive
Connect to authentication providers
Authentication connections with Microsoft Entra ID, Google, or custom providers, allow you to sign in and use your identity to access resources in various parts of the application.
Learn more about connecting to authentication providers
