Share a Gaussian splat layer
With ArcGIS Pro, you can share Gaussian splat layers
from a scene to ArcGIS Online and ArcGIS Enterprise 12.1 or later. Gaussian splat layers allow you to visualize photorealistic 3D geospatial data with complex geometries in high fidelity.
Learn more about Gaussian splat layers
To share a Gaussian splat layer, you must have the following:
An account that is part of an ArcGIS organization with the privilege to create content
An account with privileges to publish hosted tile layers
A portal configured with an ArcGIS Data Store object store if you are sharing to ArcGIS Enterprise 12.1 or later
You can continue to work with ArcGIS Pro while your sharing job is processing. You can also close ArcGIS Pro. You can monitor the status of your sharing job in the Job Status pane.
Share a Gaussian splat layer using the default configuration
To share a Gaussian splat layer with the default settings, complete the steps below. To change the default configuration, see Configure a Gaussian splat layer.
In a scene, select a Gaussian splat layer from the 3D Layers category of the Contents pane, right-click the selected layer, point to the Sharing menu, and click Share As Web Layer
.The Share As Web Layer pane appears.
Provide a name for the web layer.
The default name is the name of the layer.
Optionally, complete the Summary and Tags fields.
You can use the Tags drop-down menu to select existing tags. You can enter a maximum of 128 tags.
Optionally, use the Categories drop-down menu to assign content categories.
You can assign a maximum of 20 categories.
Under Location, use the Folder menu to choose a folder in your portal content to store the web layer or create a folder.
By default, the web layer is stored at the root level of your portal content.
Tip:
Click the Browse button
to browse to a folder in your portal content. You can also type a folder name in the search box.Under Sharing Level, specify how the web layer will be shared:
Owner—Only the owner (and organization members with privileges to view content owned by other members) can access the item. This is the default option.
Organization—Share your content with all authenticated users in your organization. This option is available when you are signed in with an organizational account.
Everyone (public)—Share your content with the public. Anyone can access and see it.
- Optionally, under Groups, select groups to which you belong to share your content with their members.
Under Finish Sharing, click Analyze
to review for potential problems.Errors and warnings are listed on the Messages tab. Right-click a message to open its help topic or take corrective action in the software. Errors
must be resolved before you can share your GIS resource. Resolving warnings
is recommended but not required.After you resolve errors, and optionally, resolve warnings, click Publish
to share the web layer.Optionally, click Jobs
to monitor the job status.When the web layer is successfully published, click the Manage the web layer link at the bottom of the pane to access the web layer in your portal.
Considerations when sharing to other portals
Gaussian splat layers cannot be shared to ArcGIS Enterprise 12.0 or earlier.
