Share a web imagery layer
With ArcGIS Pro, you can author and share web imagery layers
to ArcGIS Enterprise. These web layers expose the selected raster or mosaic dataset and can be configured to draw dynamically from data or from new or existing cached tiles. The default configuration allows users to view the dataset and its associated metadata.
To share a web imagery layer, you must have the following:
An account that is part of an ArcGIS organization with the privilege to create content
An account with privileges to publish server-based layers.
A portal configured with an image server.
While in the process of sharing a web imagery layer, you may decide to save a service definition instead. A service definition compiles information into a single file, allowing you to share the web imagery layer at a later time. Information about saving a service definition is included in the workflow below. To learn more, see Introduction to saving service definitions.
You can also use ArcPy to share a web imagery layer to a portal. To learn more, see Automate sharing web layers.
Share a web imagery layer using the default configuration
This workflow explains how to share a web imagery layer to the active ArcGIS Enterprise portal using default settings. To change the default configuration, see Configure a web imagery layer.
To share a web imagery layer, do one of the following:
In the Contents pane, select a raster or mosaic layer. Right-click the selected layer, point to Sharing, and click Share As Web Layer
.Right-click a raster or mosaic dataset in the Catalog pane and click Share As Web Layer
The Share As Web Layer pane appears.
Provide a name for the web layer.
Optionally, complete the Summary and Tags fields.
A summary and tags are required when sharing to an ArcGIS Enterprise 10.9 or earlier portal.
You can use the Tags drop-down menu to select existing tags. You can enter a maximum of 128 tags.
Optionally, use the Categories drop-down menu to assign content categories.
You can assign a maximum of 20 categories.
Do one of the following:
If you are sharing a raster or mosaic layer from a map, under Data and Layer Type, click Imagery under one of the two data types:
Reference registered data—Data that is registered with the server is referenced rather than copied to the server.
Copy all data—All data is copied to the server.
If you are sharing a dataset in the Catalog pane, choose Reference registered data or Copy all data.
For information, see Understanding reference registered data and copy all data.
Under Location, use the Portal Folder menu to choose a folder in your portal content to store the web layer. Optionally, create a folder.
By default, the web layer is stored at the root level of your portal content.
Tip:
Click the Browse button
to browse to a folder in your portal content. You can also type a folder name in the text box.Use the Server and Folder drop-down menus to specify the federated server where the service will be published and the folder where it will be stored. Optionally, create a folder.
By default, the service is stored in the root folder of the server.
You can click the Data Stores button
to open the Manage Registered Data Stores pane. Use this pane to register geodatabases and folders with federated servers.Under Sharing Level, specify how the web layer will be shared:
Owner—Only the owner (and organization members with privileges to view content owned by other members) can access the item. This is the default option.
Organization—Share your content with all authenticated users in your organization. This option is available when you are signed in with an organizational account.
Everyone (public)—Share your content with the public. Anyone can access and see it.
- Optionally, under Groups, select groups to which you belong to share your content with their members.
Optionally, click the Content tab to view the folder and new web layer.
Under Finish Sharing, click Analyze
to review for potential problems.Errors and warnings are listed on the Messages tab. Right-click a message to open its help topic or take corrective action in the software. Errors
must be resolved before you can share your GIS resource. Resolving warnings
is recommended but not required.After you have resolved errors, and optionally, resolved warnings, click Publish
to share the web layer.To save a service definition for the web layer instead, click the Publish drop-down arrow and click Save As SD. To learn more, see Save a service definition for a web layer.
When the web layer is successfully published, click the Manage the web layer link at the bottom of the pane to access the web layer in your portal.
If the web layer will be drawn from cache built automatically on the server, the web layer may not be viewable while cache generation is in progress. Click Jobs
to view the cache status in the Job Status pane.
You cannot share web imagery layers to Portal for ArcGIS 10.3.1 or earlier.
Share data in the cloud
To access and share your data in the cloud, first you must create a connection to your cloud stores, access the data using the cloud store connection file (.acs), and follow the steps to share a web imagery layer.
To share your data in the cloud, you can use one of the following options:
Share by referencing the data.
You can register the folder containing the ArcGIS cloud storage connection file (
.acs) as a data store in ArcGIS Pro.You can register a cloud store in ArcGIS Server Manager.
You can register your cloud location as a data store item in the ArcGIS Enterprise portal.
Share by copying all data, which downloads a copy of the data from the cloud, packages it, and uploads it to the federated server running ArcGIS Server.
To share by reference, you must register either the
.acsfile location or the cloud path as a data store or data store item before sharing the data.To share a mosaic dataset with data in the cloud, you must register the cloud path as a data store or data store item before sharing the data.
