ArcGIS.Desktop.Framework Namespace / IPlugInWrapper Interface / Checked Property
Example
    Checked Property
    Gets or sets the checked state of the plug-in if applicable.
    Syntax
    Property Checked As Boolean
    bool Checked {get; set;}
    Example
    Programmatically start Edit Annotation
    // programmatically activates the Edit Annotation tool by invoking the corresponding
    // plugin. The tool must be enabled for the operation to succeed.
      var plugin = FrameworkApplication.GetPlugInWrapper("esri_editing_EditVerticesText");
      if (plugin.Enabled)
        ((ICommand)plugin).Execute(null);
    Requirements
