ArcGIS.Desktop.Framework Namespace / IPlugInWrapper Interface
Properties
    IPlugInWrapper Interface Members
    The following tables list the members exposed by IPlugInWrapper.
    Public Properties
     NameDescription
     Property Gets or sets the visible name.
     Property Gets or sets the checked state of the plug-in if applicable.
     Property Gets the DAML IDs of all child controls if applicable.
     Property Gets the type of plug-in.
     Property Gets or sets the tooltip when the plug-in is disabled.
     Property Gets a boolean value indicating if the plug-in is enabled in the user interface.
     Property Gets a boolean value of true if the plugin is currently contextually relevant.
     Property Gets the DAML Keytip text.
     Property Gets or sets the image the plug-in should use in the user interface when it is in its large state (32x32).
     Property Gets or sets the image the plug-in should use in the user interface when it is in its small state (16x16).
     Property Gets or sets the text to appear in a pop-up window to give more information about the plug-in.
     Property Gets or sets the caption to appear above the tooltip in a pop-up window to give more information about the plug-in.
    Top
