ArcGIS.Desktop.Framework Namespace / IPlugInWrapper Interface / SmallImage Property
Example
    SmallImage Property (IPlugInWrapper)
    Gets or sets the image the plug-in should use in the user interface when it is in its small state (16x16).
    Syntax
    Property SmallImage As Object
    object SmallImage {get; set;}
    Example
    Programmatically start Edit Annotation
    // programmatically activates the Edit Annotation tool by invoking the corresponding
    // plugin. The tool must be enabled for the operation to succeed.
      var plugin = FrameworkApplication.GetPlugInWrapper("esri_editing_EditVerticesText");
      if (plugin.Enabled)
        ((ICommand)plugin).Execute(null);
    Change a buttons caption or image
      IPlugInWrapper wrapper = FrameworkApplication.GetPlugInWrapper("MyAddin_MyCustomButton");
      if (wrapper != null)
        wrapper.Caption = "new caption";
        // ensure that T-Rex16 and T-Rex32 are included in your add-in under the images folder and have
        // BuildAction = Resource and Copy to OutputDirectory = Do not copy
        wrapper.SmallImage = buildImage;
        wrapper.LargeImage = buildImage2;
    Requirements
