ArcGIS.Desktop.Framework Namespace / RelayCommand Class / RelayCommand Constructor / RelayCommand Constructor(Func<Task>,Boolean)
The method to call.
Is the command automatically called for a state update. Default is true.
    Instantiates a new RelayCommand instance.
    Syntax
    Public Function New( _
       ByVal execute As Func(Of Task), _
       Optional ByVal supportsOnUpdate As Boolean _
    public RelayCommand(
       Func<Task> execute,
       bool supportsOnUpdate
    Parameters
    execute
    The method to call.
    supportsOnUpdate
    Remarks
    If supportsOnUpdate is true, the default, the command will automatically disable whenever the main worker thread is busy and when the application begins shutting down.
    Requirements
