Public MustInherit Class ComboBox Inherits PlugIn Implements System.ComponentModel.INotifyPropertyChanged
public abstract class ComboBox : PlugIn, System.ComponentModel.INotifyPropertyChanged
All ribbon control elements share several attributes. The loadOnClick attribute determines when the control should be created by the framework. By default, controls appear enabled, but are not actually instantiated until they are clicked. This simple just-in-time (JIT) strategy improves resource utilization and startup time by deferring the instantiation of controls until they are initiated by the end user. Note that non-visible controls are never loaded until they become visible (or are executed programmatically), regardless of the value assigned to loadOnClick.
Tooltips are defined using the tooltip sub-element and may span as many lines as necessary. The image attribute is used to supply an image that will appear next to the tip text. Command tooltips also support a disabledText element, this string is additional displayed when the command is disabled.
Most controls support multiple sizes in the ribbon. For example, a button can render small (small icon only), medium (small icon with text), and large (large icon over text). Use the smallImage and largeImage attributes to specify unique images for the different sizes. Images don’t have to be graphics, you can also use XAML. You can also use overlayLargeImage and overlaySmallImage to draw a graphic or XAML overtop of the corresponding images. If the image should flip when running right-to-left, e.g. arrow buttons, set the flipImageRTL attribute to true.
The disableIfBusy element is used to signal that the control should be disabled whenever the primary worker thread is busy. This prevents work from queuing up. This element is true by default. Controls that always need to be enabled such as the close application button should set this to false.
All control declarations support a condition attribute allowing the assignment of a condition. If the specified condition isn’t met, the control will be automatically disabled by the framework. In addition, controls remain unloaded until their is met. If no condition is specified, the control is assumed to be always relevant.
The ComboBox allows the user to select an item from a drop-down list or optionally to enter new text in the text box of the control. A ComboBox can contain a collection of objects of any type (such as string or image).
The IsEditable and IsReadOnly attributes specify how the ComboBox behaves.
| IsReadOnly true | IsReadOnly false | |
| IsEditable true |
| IsEditable false |
Declaring ComboBoxes in DAML: <comboBox id="acme_cityComboBox"
caption="Cities"
isEditable="false"
isReadOnly="true"
isTextSearchEnabled="true"
editHint="Select a city..."
className="CityComboBox"
sizeString="areallylongcityname"
image="pack://application:,,,/Acme;component/Images/Cities16.png">
<tooltip heading="Major Cities">Select a major city.</tooltip>
</comboBox>
| DAML attributes | |
| id | Required identifier. |
| caption | The text to appear beside the combo box. |
| extendedCaption | A more descriptive title. |
| dataTemplateFile | The path to the file containing the custom item template |
| editHint | The text to display when the combo box is empty. |
| image | An image to optionally show beside the combo box. |
| itemHeight | Used with the number of rows to calculate the maximum height of the combo box drop-down. |
| itemWidth | Used to size the combo box if the sizeString is empty. |
| isEditable | Enables or disables editing of the text in text box. Default is true. |
| isReadOnly | Sets the selection-only mode, in which the contents of the combo box are selectable but not editable. Default is false. |
| resizable | Is the combo box drop-down resizable. |
| rows | The number of rows to show in the combo box drop-down |
| templateID | The template ID in the dataTemplateFile. |
| sizeString | The control sizes to accommodate the sizeString. |
| isTextSearchEnabled | Enables a user to quickly access items in a set by typing prefixes of strings. Default is true. |
| categoryRefID | Adds combo box to a specific component category. |
| condition | Automatically disable the combo box if the condition is not satisfied. |
| disableIfBusy | Automatically disable the combo box if the application is busy. Default true. |
| helpContextID | The help topic to show. |
| className | Required class identifier. Optionally include namespace if not in default namespace. |
| assembly | Assembly name if not in the default assembly. |
| publicKeyToken | The necessary public key token if the assembly is strongly named. |
| version | The version of the dll if the assembly is strongly named. |
| DAML Child Elements | |
| tooltip | Description of the control. |
| content | Optional custom XML data when registered in a component category. |
System.Object
ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
ArcGIS.Desktop.Framework.Contracts.PlugIn
ArcGIS.Desktop.Framework.Contracts.ComboBox
