ArcGIS.Desktop.Framework.Contracts Namespace / ComboBox Class
Properties Methods Events
    ComboBox Class Members
    The following tables list the members exposed by ComboBox.
    Public Properties
     NameDescription
    Public Property Gets or sets the command label as it appears in the ribbon and customize dialog. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public PropertyGets or sets the supplementary text that appears with the Tooltip only when the command is disabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a boolean to specify whether the control is enabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets the DAML identifier. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets the combo box items.
    Public Property Gets or sets the large representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets the zero-based index of the selected item.
    Public Property Gets or sets the selected combo box item.
    Public Property Gets or sets the small representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets the text of the currently selected item.
    Public Property Gets or sets a brief description of the command that appears in a small pop-up window when a user pauses the mouse pointer over an element, such as over a Button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a one or two word label that appears above the tooltip. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Top
    Protected Properties
     NameDescription
    Protected Internal Property Gets or sets the custom item template.
    Top
    Protected Methods
     NameDescription
    Protected Method Adds an item to the collection.
    Protected Method Removes all the items from the internal collection.
    Protected Method Add items from an existing collection.
    Protected Method Inserts an element into the collection at the specified index.
    Protected Method Moves the item at the specified index to a new location in the collection.
    Protected MethodOverloaded.  (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase)
    Protected Internal Method Invoked when the combo box's drop-down list is opened.
    Protected Internal Method Invoked when the 'Enter' key is pressed inside the combo box's textbox.
    Protected Internal Method Invoked when the combo box loses keyboard focus.
    Protected Internal MethodOverloaded.
    Protected Internal Method Invoked when the text in the combo box's textbox changes.
    Protected Internal Method Called periodically by the framework once the tool has been created. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Protected Method Removes the first occurrence of a specific object from the collection.
    Protected Method Removes the element at the specified index of the collection.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase)
    Top
