ArcGIS.Desktop.Framework.Contracts Namespace / ComboBox Class / Remove Method
The item being removed from the combo box.
    Remove Method (ComboBox)
    Removes the first occurrence of a specific object from the collection.
    Syntax
    protected bool Remove(
       object item
    Protected Function Remove( _
       ByVal item As Object _
    ) As Boolean
    Parameters
    item
    Return Value
    True if successfully removed; otherwise, false. This method also returns false if the object was not found in the collection.
    Requirements
