| Name | Description | |
![]() | ActiveRangeName | Gets or sets the active range name. |
![]() | BindVariables | Gets or sets the bind variables. |
![]() | DatabaseRelates | Gets or sets overrides for database relationships as relationship info. |
![]() | DefinitionExpression | Gets or sets the definition expression that can subset the rows in the layer or table. |
![]() | DefinitionExpressionName | Gets or sets the name of the active definition expression. |
![]() | DefinitionFilterChoices | Gets or sets the definition filter choices. |
![]() | DisplayExpressionInfo | Gets or sets the expression information used for coming up with a string that represents a row or a feature. This property takes precedence over DisplayField. |
![]() | DisplayField | Gets or sets the name of the attribute field that will be used as a label that represents each row in the layer or table. The display field must be able to be represented as a string (string or numeric). |
![]() | Editable | Gets or sets a value indicating whether or not the layer or table can be edited. |
![]() | FieldDescriptions | Gets or sets the field descriptions. Field descriptions for fields may only be written if values are overridden from defaults. |
![]() | FloorAwareTableProperties | Gets or sets floor-aware properties for the layer or table used in floor filtering. |
![]() | FormInfo | Gets or sets the form information for the layer or table. |
![]() | RangeDefinitions | Gets or sets the range definitions. |
![]() | Relates | Gets or sets the relates. |
![]() | RouteIDFieldName | Gets or sets the route identifier field of a route feature class. |
![]() | SelectionSetURI | Gets or sets the URI of the selection set for the layer or table. |
![]() | SelectRelatedData | Gets or sets a value indicating whether related data should be selected when creating a new selection. |
![]() | SubtypeValue | Gets or sets the subtype value that should be used in the feature layer definition. This property is honored only when feature layer is a member of SubtypeLayer. |
![]() | TimeDefinition | Gets or sets the time definition. |
![]() | TimeDimensionFields | Gets or sets the time definition fields. |
![]() | TimeDisplayDefinition | Gets or sets the time display definition. |
![]() | TimeFields | Gets or sets the time fields. |
![]() | UseSubtypeValue | Gets or sets a value indicating whether or not the SubtypeValue should be used. |
