ArcGIS.Desktop.Framework.DragDrop Namespace / DropTargetAdorner Class
    DropTargetAdorner Class Methods
    For a list of all members of this type, see DropTargetAdorner members.
    Public Methods
     NameDescription
    Public MethodOverloaded.  (Inherited from System.Windows.UIElement)
    Public MethodAdds handlers to the specified System.Windows.EventRoute for the current System.Windows.UIElement event handler collection. (Inherited from System.Windows.UIElement)
    Public MethodBuilds the current template's visual tree if necessary, and returns a value that indicates whether the visual tree was rebuilt by this call. (Inherited from System.Windows.FrameworkElement)
    Public MethodPositions child elements and determines a size for a System.Windows.UIElement. Parent elements call this method from their System.Windows.UIElement.ArrangeCore(System.Windows.Rect) implementation (or a WPF framework-level equivalent) to form a recursive layout update. This method constitutes the second pass of a layout update. (Inherited from System.Windows.UIElement)
    Public MethodStarts the initialization process for this element. (Inherited from System.Windows.FrameworkElement)
    Public MethodOverloaded.  (Inherited from System.Windows.FrameworkElement)
    Public MethodAttempts to force capture of the mouse to this element. (Inherited from System.Windows.UIElement)
    Public MethodAttempts to force capture of the stylus to this element. (Inherited from System.Windows.UIElement)
    Public MethodAttempts to force capture of a touch to this element. (Inherited from System.Windows.UIElement)
    Public MethodOverloaded.  (Inherited from System.Windows.DependencyObject)
    Public MethodCoerces the value of the specified dependency property. This is accomplished by invoking any System.Windows.CoerceValueCallback function specified in property metadata for the dependency property as it exists on the calling System.Windows.DependencyObject. (Inherited from System.Windows.DependencyObject)
    Public Method Removes the specified adorner from the adorner layer.
    Public MethodIndicates that the initialization process for the element is complete. (Inherited from System.Windows.FrameworkElement)
    Public Method (Inherited from System.Windows.DependencyObject)
    Public MethodReturns the common ancestor of two visual objects. (Inherited from System.Windows.Media.Visual)
    Public Method (Inherited from System.Windows.FrameworkElement)
    Public MethodSearches for a resource with the specified key, and throws an exception if the requested resource is not found. (Inherited from System.Windows.FrameworkElement)
    Public MethodAttempts to set focus to this element. (Inherited from System.Windows.UIElement)
    Public MethodReturns the base property value for the specified property on this element, disregarding any possible animated value from a running or stopped animation. (Inherited from System.Windows.UIElement)
    Public MethodReturns the System.Windows.Data.BindingExpression that represents the binding on the specified property. (Inherited from System.Windows.FrameworkElement)
    Public MethodReturns a System.Windows.Media.Transform for the adorner, based on the transform that is currently applied to the adorned element. (Inherited from System.Windows.Documents.Adorner)
    Public MethodGets a hash code for this System.Windows.DependencyObject. (Inherited from System.Windows.DependencyObject)
    Public MethodCreates a specialized enumerator for determining which dependency properties have locally set values on this System.Windows.DependencyObject. (Inherited from System.Windows.DependencyObject)
    Public MethodReturns the current effective value of a dependency property on this instance of a System.Windows.DependencyObject. (Inherited from System.Windows.DependencyObject)
    Public Method (Inherited from System.Windows.UIElement)
    Public MethodInvalidates the arrange state (layout) for the element. After the invalidation, the element will have its layout updated, which will occur asynchronously unless subsequently forced by System.Windows.UIElement.UpdateLayout. (Inherited from System.Windows.UIElement)
    Public MethodInvalidates the measurement state (layout) for the element. (Inherited from System.Windows.UIElement)
    Public MethodInvalidates the rendering of the element, and forces a complete new layout pass. System.Windows.UIElement.OnRender(System.Windows.Media.DrawingContext) is called after the layout cycle is completed. (Inherited from System.Windows.UIElement)
    Public MethodDetermines whether the visual object is an ancestor of the descendant visual object. (Inherited from System.Windows.Media.Visual)
    Public MethodDetermines whether the visual object is a descendant of the ancestor visual object. (Inherited from System.Windows.Media.Visual)
    Public MethodUpdates the System.Windows.UIElement.DesiredSize of a System.Windows.UIElement. Parent elements call this method from their own System.Windows.UIElement.MeasureCore(System.Windows.Size) implementations to form a recursive layout update. Calling this method constitutes the first pass (the "Measure" pass) of a layout update. (Inherited from System.Windows.UIElement)
    Public MethodMoves the keyboard focus away from this element and to another element in a provided traversal direction. (Inherited from System.Windows.FrameworkElement)
    Public MethodWhen overridden in a derived class, is invoked whenever application code or internal processes call System.Windows.FrameworkElement.ApplyTemplate. (Inherited from System.Windows.FrameworkElement)
    Public MethodConverts a System.Windows.Point in screen coordinates into a System.Windows.Point that represents the current coordinate system of the System.Windows.Media.Visual. (Inherited from System.Windows.Media.Visual)
    Public MethodConverts a System.Windows.Point that represents the current coordinate system of the System.Windows.Media.Visual into a System.Windows.Point in screen coordinates. (Inherited from System.Windows.Media.Visual)
    Public MethodDetermines the next element that would receive focus relative to this element for a provided focus movement direction, but does not actually move the focus. (Inherited from System.Windows.FrameworkElement)
    Public MethodReturns the local value of a dependency property, if it exists. (Inherited from System.Windows.DependencyObject)
    Public MethodProvides an accessor that simplifies access to the System.Windows.NameScope registration method. (Inherited from System.Windows.FrameworkElement)
    Public MethodReleases all captured touch devices from this element. (Inherited from System.Windows.UIElement)
    Public MethodReleases the mouse capture, if this element held the capture. (Inherited from System.Windows.UIElement)
    Public MethodReleases the stylus device capture, if this element held the capture. (Inherited from System.Windows.UIElement)
    Public MethodAttempts to release the specified touch device from this element. (Inherited from System.Windows.UIElement)
    Public MethodSearches for a resource with the specified name and sets up a resource reference to it for the specified property. (Inherited from System.Windows.FrameworkElement)
    Public MethodOverloaded.  (Inherited from System.Windows.Media.Visual)
    Public MethodReturns a transform that can be used to transform coordinates from the System.Windows.Media.Visual to the specified visual object descendant. (Inherited from System.Windows.Media.Visual)
    Public MethodReturns a transform that can be used to transform coordinates from the System.Windows.Media.Visual to the specified visual object. (Inherited from System.Windows.Media.Visual)
    Public MethodTranslates a point relative to this element to coordinates that are relative to the specified element. (Inherited from System.Windows.UIElement)
    Public MethodSearches for a resource with the specified key, and returns that resource if found. (Inherited from System.Windows.FrameworkElement)
    Public MethodSimplifies access to the System.Windows.NameScope de-registration method. (Inherited from System.Windows.FrameworkElement)
    Public MethodReapplies the default style to the current System.Windows.FrameworkElement. (Inherited from System.Windows.FrameworkElement)
    Public MethodEnsures that all visual child elements of this element are properly updated for layout. (Inherited from System.Windows.UIElement)
    Top
    Protected Methods
     NameDescription
    Protected Internal MethodAdds the provided object to the logical tree of this element. (Inherited from System.Windows.FrameworkElement)
    Protected MethodDefines the parent-child relationship between two visuals. (Inherited from System.Windows.Media.Visual)
    Protected MethodImplements System.Windows.UIElement.ArrangeCore(System.Windows.Rect) (defined as virtual in System.Windows.UIElement) and seals the implementation. (Inherited from System.Windows.FrameworkElement)
    Protected MethodWhen overridden in a derived class, positions child elements and determines a size for a System.Windows.FrameworkElement derived class. (Inherited from System.Windows.FrameworkElement)
    Protected MethodFor a description of this member, see System.Windows.UIElement.GetLayoutClip(System.Windows.Size). (Inherited from System.Windows.Documents.Adorner)
    Protected Internal MethodReturns the named element in the visual tree of an instantiated System.Windows.Controls.ControlTemplate. (Inherited from System.Windows.FrameworkElement)
    Protected Internal MethodReturns an alternative logical parent for this element if there is no visual parent. (Inherited from System.Windows.FrameworkElement)
    Protected MethodOverrides System.Windows.Media.Visual.GetVisualChild(System.Int32), and returns a child at the specified index from a collection of child elements. (Inherited from System.Windows.FrameworkElement)
    Protected MethodOverloaded.  (Inherited from System.Windows.UIElement)
    Protected MethodImplements basic measure-pass layout system behavior for System.Windows.FrameworkElement. (Inherited from System.Windows.FrameworkElement)
    Protected MethodImplements any custom measuring behavior for the adorner. (Inherited from System.Windows.Documents.Adorner)
    Protected MethodProvides class handling for when an access key that is meaningful for this element is invoked. (Inherited from System.Windows.UIElement)
    Protected MethodSupports layout behavior when a child element is resized. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked whenever an unhandled System.Windows.FrameworkElement.ContextMenuClosing routed event reaches this class in its route. Implement this method to add class handling for this event. (Inherited from System.Windows.FrameworkElement)
    Protected MethodInvoked whenever an unhandled System.Windows.FrameworkElement.ContextMenuOpening routed event reaches this class in its route. Implement this method to add class handling for this event. (Inherited from System.Windows.FrameworkElement)
    Protected MethodReturns class-specific System.Windows.Automation.Peers.AutomationPeer implementations for the Windows Presentation Foundation (WPF) infrastructure. (Inherited from System.Windows.UIElement)
    Protected MethodCalled when the DPI at which this View is rendered changes. (Inherited from System.Windows.Media.Visual)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.DragEnter attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.DragLeave attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.DragOver attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.GiveFeedback attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked whenever an unhandled System.Windows.UIElement.GotFocus event reaches this element in its route. (Inherited from System.Windows.FrameworkElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Keyboard.GotKeyboardFocus attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.GotMouseCapture attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.GotStylusCapture attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.GotTouchCapture routed event that occurs when a touch is captured to this element. (Inherited from System.Windows.UIElement)
    Protected MethodRaises the System.Windows.FrameworkElement.Initialized event. This method is invoked whenever System.Windows.FrameworkElement.IsInitialized is set to %[LangWord]true %internally. (Inherited from System.Windows.FrameworkElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsKeyboardFocusedChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked just before the System.Windows.UIElement.IsKeyboardFocusWithinChanged event is raised by this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsMouseCapturedChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsMouseCaptureWithinChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsMouseDirectlyOverChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsStylusCapturedChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsStylusCaptureWithinChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.IsStylusDirectlyOverChanged event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Keyboard.KeyDown attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Keyboard.KeyUp attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodRaises the System.Windows.UIElement.LostFocus routed event by using the event data that is provided. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Keyboard.LostKeyboardFocus attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.LostMouseCapture attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.LostStylusCapture attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.LostTouchCapture routed event that occurs when this element loses a touch capture. (Inherited from System.Windows.UIElement)
    Protected MethodCalled when the System.Windows.UIElement.ManipulationBoundaryFeedback event occurs. (Inherited from System.Windows.UIElement)
    Protected MethodCalled when the System.Windows.UIElement.ManipulationCompleted event occurs. (Inherited from System.Windows.UIElement)
    Protected MethodCalled when the System.Windows.UIElement.ManipulationDelta event occurs. (Inherited from System.Windows.UIElement)
    Protected MethodCalled when the System.Windows.UIElement.ManipulationInertiaStarting event occurs. (Inherited from System.Windows.UIElement)
    Protected MethodCalled when the System.Windows.UIElement.ManipulationStarted event occurs. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.ManipulationStarting routed event that occurs when the manipulation processor is first created. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.MouseDown attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.MouseEnter attached event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.MouseLeave attached event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.MouseLeftButtonDown routed event is raised on this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.MouseLeftButtonUp routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.MouseMove attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.MouseRightButtonDown routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.MouseRightButtonUp routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.MouseUp routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.MouseWheel attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.PreviewDragEnter attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.PreviewDragLeave attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.PreviewDragOver attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.PreviewDrop attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.PreviewGiveFeedback attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Keyboard.PreviewGotKeyboardFocus attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Keyboard.PreviewKeyDown attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Keyboard.PreviewKeyUp attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.PreviewMouseDown attached routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.PreviewMouseLeftButtonDown routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.PreviewMouseLeftButtonUp routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.PreviewMouseMove attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.PreviewMouseRightButtonDown routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.UIElement.PreviewMouseRightButtonUp routed event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.PreviewMouseUp attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.PreviewMouseWheel attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.PreviewQueryContinueDrag attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusButtonDown attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusButtonUp attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusDown attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusInAirMove attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusInRange attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusMove attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusOutOfRange attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusSystemGesture attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.PreviewStylusUp attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.TextCompositionManager.PreviewTextInput attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.PreviewTouchDown routed event that occurs when a touch presses this element. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.PreviewTouchMove routed event that occurs when a touch moves while inside this element. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.PreviewTouchUp routed event that occurs when a touch is released inside this element. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked whenever the effective value of any dependency property on this System.Windows.FrameworkElement has been updated. The specific dependency property that changed is reported in the arguments parameter. Overrides System.Windows.DependencyObject.OnPropertyChanged(System.Windows.DependencyPropertyChangedEventArgs). (Inherited from System.Windows.FrameworkElement)
    Protected MethodInvoked when an unhandled System.Windows.DragDrop.QueryContinueDrag attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Mouse.QueryCursor attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodWhen overridden in a derived class, participates in rendering operations that are directed by the layout system. The rendering instructions for this element are not used directly when this method is invoked, and are instead preserved for later asynchronous use by layout and drawing. (Inherited from System.Windows.UIElement)
    Protected Internal MethodRaises the System.Windows.FrameworkElement.SizeChanged event, using the specified information as part of the eventual event data. (Inherited from System.Windows.FrameworkElement)
    Protected Internal Method (Inherited from System.Windows.FrameworkElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusButtonDown attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusButtonUp attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusDown attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusEnter attached event is raised by this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusInAirMove attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusInRange attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusLeave attached event is raised by this element. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusMove attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusOutOfRange attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusSystemGesture attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.Stylus.StylusUp attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked when an unhandled System.Windows.Input.TextCompositionManager.TextInput attached event reaches an element in its route that is derived from this class. Implement this method to add class handling for this event. (Inherited from System.Windows.UIElement)
    Protected MethodInvoked whenever an unhandled System.Windows.FrameworkElement.ToolTipClosing routed event reaches this class in its route. Implement this method to add class handling for this event. (Inherited from System.Windows.FrameworkElement)
    Protected MethodInvoked whenever the System.Windows.FrameworkElement.ToolTipOpening routed event reaches this class in its route. Implement this method to add class handling for this event. (Inherited from System.Windows.FrameworkElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.TouchDown routed event that occurs when a touch presses inside this element. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.TouchEnter routed event that occurs when a touch moves from outside to inside the bounds of this element. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.TouchLeave routed event that occurs when a touch moves from inside to outside the bounds of this System.Windows.UIElement. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.TouchMove routed event that occurs when a touch moves while inside this element. (Inherited from System.Windows.UIElement)
    Protected MethodProvides class handling for the System.Windows.UIElement.TouchUp routed event that occurs when a touch is released inside this element. (Inherited from System.Windows.UIElement)
    Protected Internal MethodCalled when the System.Windows.Media.VisualCollection of the visual object is modified. (Inherited from System.Windows.Media.Visual)
    Protected Internal MethodInvoked when the parent of this element in the visual tree is changed. Overrides System.Windows.UIElement.OnVisualParentChanged(System.Windows.DependencyObject). (Inherited from System.Windows.FrameworkElement)
    Protected Internal MethodSupports incremental layout implementations in specialized subclasses of System.Windows.FrameworkElement. System.Windows.FrameworkElement.ParentLayoutInvalidated(System.Windows.UIElement) is invoked when a child element has invalidated a property that is marked in metadata as affecting the parent's measure or arrange passes during layout. (Inherited from System.Windows.FrameworkElement)
    Protected Internal MethodRemoves the provided object from this element's logical tree. System.Windows.FrameworkElement updates the affected logical tree parent pointers to keep in sync with this deletion. (Inherited from System.Windows.FrameworkElement)
    Protected MethodRemoves the parent-child relationship between two visuals. (Inherited from System.Windows.Media.Visual)
    Protected Internal MethodReturns a value that indicates whether serialization processes should serialize the value for the provided dependency property. (Inherited from System.Windows.DependencyObject)
    Top
