ArcGIS.Desktop.Layouts Namespace / ScaleBar Class
Members Example
    ScaleBar Class
    Represents a scale bar on a page layout. Represents a scale bar on a page layout
    Object Model
    ScaleBar ClassCoordinate2D StructureEnvelope ClassCIMElement ClassGeometry ClassIElementContainer InterfaceMapFrame Class
    Syntax
    Remarks
    There are currently no additional members but this class can be used to determine the type of MapSurround..
    Example
    Create Scale Bar
      //Note: Must be on QueuedTask.Run
      //Build geometry
      Coordinate2D ll = new Coordinate2D(5.0, 6);
      Coordinate2D ur = new Coordinate2D(6.0, 7);
      Envelope sbEnv = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
      //Reference a Scale Bar in a style
      StyleProjectItem stylePrjItm = Project.Current.GetItems<StyleProjectItem>()
                    .FirstOrDefault(item => item.Name == "ArcGIS 2D");
      ScaleBarStyleItem sbStyleItm = stylePrjItm.SearchScaleBars(
                   "Alternating Scale Bar 1")[0];
      //ScaleBarStyleItem sbStyleItm = stylePrjItm.SearchScaleBars(
      //                                   "Double Alternating Scale Bar 1")[0];
      //                                    "Hollow Scale Bar 1")[0];
      //Create Scale Bar
      ScaleBarInfo sbInfo = new ScaleBarInfo()
        MapFrameName = mapFrame.Name,
      var sbElm = ElementFactory.Instance.CreateMapSurroundElement(
                                         layout, sbEnv, sbInfo) as ScaleBar;
    Create Scale Line
      //Build geometry
      Coordinate2D ll = new Coordinate2D(5.0, 8);
      Coordinate2D ur = new Coordinate2D(6.0, 9);
                                    "Scale Line 1")[0];
      //                                           "Stepped Scale Line")[0];
      //                                            "Scale Line 2")[0];
      //Create Scale Bar
        ScaleBarStyleItem = sbStyleItm
                        layout, sbEnv, sbInfo, "ScaleBar Line") as ScaleBar;
    Update a map surround
      //Update a map surround.
      // Reference and load the layout associated with the layout item
      // Reference a scale bar element by name
      MapSurround scaleBar = layout.FindElement("MyScaleBar") as MapSurround;
      // Reference a map frame element by name
      MapFrame mf = layout.FindElement("MyMapFrame") as MapFrame;
      if ((scaleBar != null) && (mf != null))
        //Set the scale bar to the newly referenced map frame
        scaleBar.SetMapFrame(mf);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Layouts.Element
             ArcGIS.Desktop.Layouts.MapSurround
                ArcGIS.Desktop.Layouts.ScaleBar
    Requirements
